Cisco IP Phone 8941 as an OXE SIP Extension
moulis
Post by moulis »
Does anybody have an experience with this new Cisco IP Phone 8941 (or 8900 Series) to work as an OXE SIP Extension?
Thank you very much.
Br
Pavel
alex
Re: Cisco IP Phone 8941 as an OXE SIP Extension
Post by alex »
moulis wrote: Does anybody have an experience with this new Cisco IP Phone 8941 (or 8900 Series) to work as an OXE SIP Extension?
First of all, except for some Thomson's models certified with ALU all other SIP-hardphones supposed to be configured as SIP device.
Hi ,
I have in the past configured cisco IP phones to run on the OXE with success.
what is your question ?
ubhatnagar
Post by ubhatnagar »
Frank,
I understand you have done this. Would request you to help with the configuration details from both of the ends(Cisco Phone and OXE).
Thanks in advance.
OXE would be to enable sip and have licenses of course. To enable sip just follow documentation. Quite simple.
On Cisco side use OXE as registrar and create a SIP device on OXE to use it as user on Cisco.
What is not working for you.
ubhatnagar
I didn't option of registrar in phone.
But yes, there is an option of TFTP. And there I put Oxe ip address as well but I didn't get any register request on Oxe motortrace.
Rgds
Upendra
ubhatnagar
Actually I am using cisco 7821
So...we are more familiar with Alcatel. Easier for you would be to search on the Internet for a Cisco doc on how to configure those phones. Cisco has a lot of info around
TFTP is other things than registrar i swhere to download sip binairy and more binaries
you should search for proxy server or callserver
I don t have it with me since it has been years, but I remember having a text file (XML?) and loading it in a tftp server..
after that it was a breeze.
Return to “SIP Extension”
