CCS launch and login with command line
j79
Post by j79 »
Hi all,
I've statistics which are automaticaly generated each night.
Sometimes, CCS is crashing and we have to kill the instance (sometimes reboot the VM) launch CCS again and login so the statistics generates anew.
As I don't understand why it's crashing for now I'd like to implement a workaround.
So every night I'd like to kill EXCEL.EXE and CCS.EXE reboot the VM then relaunch CCS then login so css will be ready to generate reports.
I don't find a way to log in into ccs using command line, is there a possibility ?
thanks for your advices,
Jérôme
OXE_4400
Re: CCS launch and login with command line
Post by OXE_4400 »
Are You using newest CCS version? Which one exactly?
j79
Post by j79 »
Hi my version is 08.00.90.02
OXE_4400
Post by OXE_4400 »
Just install newest 10.1.90.4 and check again.
j79
Post by j79 »
We've planned to upgrade to 11.00 before end of april.
So there's no way to log on using command line ?
OXE_4400
Post by OXE_4400 »
I guess no.
CCS version it's not linked to OXE version, can be more new and OXE doesn't control CCS version. No need to wait til OXE R11.
Return to “CCD / CCS / CCIVR”
