My IC Anroid in Opentouch
dinusha
Post by dinusha »
Hi Friends,
i am trying to configure My Ic Anroid Mobile for Opentouch user. when i associating New MIC Anroid device to Opentouch user 8770 gives error as “Could not associate device with the user Demo User 2 OT due to Error from OT: Reverse proxy must be configured for mobile devices”
is it mandatory to have a reverse proxy for on-site mobility ?
please support me any one who did this successfully.
thank you.
Dinusha from sri lnka.
Re: My IC Anroid in Opentouch
You must fool the system. Create something there. I think I used same ICS address. Then it will work for internal users.
dinusha
Post by dinusha »
Thank You for your kind reply..
can you please tell me ho to do that configuration with out reverse proxy?
Thank you,
Dinusha.
jasic
Post by jasic »
you must manage system services -> Topology -> Reverse Proxy.
As Cav wrote. enter here you local fqdns when you don't have a RP .
You will see it work.
dinusha
Post by dinusha »
Thank you Friends,
I successfully configured My IC Anroid in Opentouch. just i configure revers proxy using opentouch url (https://opentouch.xxx.com)
in opentouch configuration -> system services -> topology -> Revers Proxy.
thanks,
Dinusha.
Return to “OTBE - OpenTouch Business Edition”
