Error coming when creating the External numbering Plan....
shahin
Post by shahin »
Hello ,
Can you please give me a solution that , i have an error message coming when i creating the External Translator ..
External Number is 523 and Internal Number is 523....
┌─Error:──────────────────────────────────────────────────┐
│ CANCEL to close this window │
│ Processing Failure │
│ OBJECT -1: First External Number: Invalid Attrib. Value │
Please kindly reply...
shahin
Re: Error coming when creating the External numbering Plan..
Post by shahin »
Hello Friends ,
Is there any update......
Maybe you have an overlap for this number...
knightrider
Post by knightrider »
do you have already any other entries in DID Translator?
shahin
Post by shahin »
yes i have already ,511,514..., i have total 19 entries....
But only the problem coming with 530,523,525..
Before it was a direct line... recently i added new other extension and exeeded the License, then all the extension became as default number.. not a direct line.
Then i added each extensions to the DID translator rule...
Please kindly help me..
Thank you...
How many translators do you have currently ?
knightrider
Probably easier if you export entire translator into text file for us to analyse.
Here at Alcatel Unleashed we open the door... but you must walk through it yourself..
shahin
Post by shahin »
thank you for giving adivise,
I have total 19 translator, we have almost 50 licenses already...
shahin
Post by shahin »
still i can add some other extensions without any error...
only these extension having the issue.....
how can i check these extension overlaping...?
anyone can give me the steps...?
it speaks for itself: First external number
So somewhere, you first internal number either already exists, or is part of a range.
Return to “Translator”
