Options on 4645
BANNAIRE
Options on 4645
Post by BANNAIRE »
Hello
4645 on OXE R9.1. After leaving a message on a set forwarded on mail box, I don't want "if you want to confirm your message, if you want to delete your message, if you want to listen to your message, press hash or whatever". What can I do ?
Thank you all
Re: Options on 4645
Hang up.
BANNAIRE
Re: Options on 4645
Post by BANNAIRE »
Hi Franck
At first, I thought it was a joke. May be, I was not clear enough. I know I can hang up at this point, but I don't want to hear any confirmation messages at all.
Re: Options on 4645
when does this message play exactly ? when you stop talking ?
BANNAIRE
Re: Options on 4645
Post by BANNAIRE »
Exactly. The system says "Press hash to terminate" and then the announcements I don' want : To confirm, press 1, to listen , press 2, to cancel, press 3.
Re: Options on 4645
I guess it is a single voice guide. Kinda funny you want to listen only the hash part and not other options. As Frank said just hang up
Re: Options on 4645
What kind of extension are you calling from ?
(Internal or external)
Because when I try in my lab, I have no voice asking me anything.
BANNAIRE
Re: Options on 4645
Post by BANNAIRE »
I get these messages wherever I call from, external through a DDI or internal.
Re: Options on 4645
I do remember them too. Maybe a version feature?
Re: Options on 4645
BANNAIRE wrote:Hi
If I call from either internal or external and stop talking, it does nothing until I push SEND (internal) or # (external).
No clue how you are doing that.
Return to “Voicemail (46x5)”
