Hi! - I moved the server over the week end to handle the daily incoming connections (about 200K/day) but it looks like I aimed too low for the resources. I'm going to have to move this server (hopefully for the last time) this week. I'm sorry for the interruption.
SNMP support
Prangers
SNMP support
Post by Prangers »
I'm trying to configure the SNMP support on my OMNI pcx device for the monitoring.
I' have a problem with the trap, i not recive nothing on the NMS system, i configured the ip address on the OMNI pcx by the Office Management Consolle but... nothing.
How i can resolve the problem ? The snmp support is normally incluse in the device ? I need something other ?
And... other two questions, how i can retrive the specified model of my TS ? And after where i retrive the MIBs of the TS device ?
Thanks!!!
Wolfis
Re: SNMP support
Post by Wolfis »
as far as I know, OxO will not support SNMP.
Sincerely, Wolfis
Prangers
Re: SNMP support
Post by Prangers »
Ok, but i'm not sure that is an oxo, maybe is an oxe. But in my omni pcx manager i have the snmp settings, it's only the interface?
The oxe has the support snmp? How i can retrive the right model?
Re: SNMP support
If you have OMC then it is an OXO.
Prangers
Re: SNMP support
Post by Prangers »
Ok, thanks,
Than, if in my OMC i have the possibility to set SNMP parameters, the Device OXO not support SNMP, it's necessary a license ?
In my OMC in the istallation Wizard i have :
Version : R1.x...R9.X
Hardware : OmniPCX
Re: SNMP support
I would say this is not yet implemented nor documented.
In the last system release (9.2) sys doc there is nothing about SNMP support. Menu is available in newer OMC versions under NMC. Also an entry related to license is seen on OMC.
Any news regarding this gents?
Return to “MAIN”
