site survey mode on Dect 400 type handset
Maqsoodulhaq
Post by Maqsoodulhaq »
DECT Phone type 400 in Site Survey Mode
Followed the sequence as mentioned below:
Switch on while holding Hang-up key + Phone book key
Allow the phone to restart
Long Press on key 9
This activate the phone on site survey mode
BUT The Display on type 400 DECT Phone shows as below
F:D S:E B : 00 0
RSSI 000 / 00H: - xx
M:0 000 / 00H: - xx
Press down Arrow Key
B000 / 00H R – xx xx
A: xx X: xx Z: xx 0
SYN: xx Qual: xx 0
RFPI 0000000000
0000000000000
No base Locking
Eliott
Re: site survey mode on Dect 400 type handset
Post by Eliott »
Looks good and quite normal, whats your problem?
You are just out of radio coverage or set is not registered.
Maqsoodulhaq
hi Eliott
Thanks for your Post & Reply
But The Base station was powered on and the Dect Handset is in coverage. Why it not registered in survey mode automatically with the Base station. I was expecting signal on Dect Handset in order to make site survey, The DAP(NEC) came along with Tripod in DECT SITE SURVEY KIT as recommended by Alcatel and we purchase it as follows:
The DAP LED Blinking & gets Reset and Blinking again, this cycle goes on and on.
IP-DECT SITE SURVEY KIT 3BN67186AA
IP-DECT SITE SURVEY TRIPOD 3BN67187AA
Please elaborate more on it
thanks
Return to “PWT/DECT System”
