checking traffic direction
eham19
Is there some commands to run to check traffic direction on a lag? Trying to look into a 7450 ring and check traffic flow. Sure this can be done easier with the SAM software but don't have that at this time.
Badger
Re: checking traffic direction
Not 100% certain about the 7450, but what about the monitor command?
- monitor
card - Monitor command for Card
ccag - Monitor traffic statistics for CCAG ports
cpm-filter + Monitor commands for CPM filters
eth-cfm + Monitor commands for ETH-CFM
filter + Monitor commands for filters
lag - Monitor traffic statistics for LAG ports
management-acc* + Monitor commands for management-access filters
port + Monitor port traffic statistics
qos + Monitor commands for QoS
router + Monitor commands for virtual router instance
service + Monitor commands for services
test-oam + Monitor commands for Operations, Administration, and
Maintenance
- monitor
Maintenance
toxkalcan
If a service is under lag of two 10Gb ports. Under lag one port is active; and the other is in standby fro redundancy. Briefly, physical capacity of LAG is 20 Gb but active only 10 Gb
For example,
Lag-id Port-id Adm Act/Stdby Opr Description
100(e) up up
4/2/1 up standby down " <<<<<<< Down 10 Gb
5/1/2 up active up <<<<<<< Up 10 Gb
My question ;
When we monitor a service under the lag with rate command, how can we intrepret the quantity of the traffic ? Is it 20 Gb or 10 Gb link ?
monitor service id 1 sap rate lag-100:1.1 rate
At time t = 11 sec (Mode: Rate)
Sap Statistics
Last Cleared Time : 06/04/2015 00:36:54
Packets Octets % Port
Util.
Forwarding Engine Stats
Dropped : 0 0 0.00
Off. HiPrio : 2028 974815 0.07
Off. LowPrio : 0 21 ~0.00
Off. Uncolor : 0 0 0.00
Queueing Stats(Ingress QoS Policy 1260)
Dro. HiPrio : 0 0 0.00
Dro. LowPrio : 0 0 0.00
For. InProf : 2028 974815 0.07
For. OutProf : 0 21 ~0.00
Queueing Stats(Egress QoS Policy 1260)
Dro. InProf : 0 0 0.00
Dro. OutProf : 0 0 0.00
For. InProf : 2215 1953677 0.15
For. OutProf : 67 9456 ~0.00
Sap per Queue Stats
Util.
Ingress Queue 1 (Unicast) (Priority)
Off. HiPrio : 0 0 0.00
Off. LoPrio : 0 0 0.00
Dro. LoPrio : 0 0 0.00
For. InProf : 0 0 0.00
For. OutProf : 0 0 0.00
Ingress Queue 2 (Unicast) (Profile)
Off. ColorIn : 2028 974815 0.07
Off. ColorOut : 0 0 0.00
Dro. ColorOut : 0 0 0.00
Dro. ColorIn & Uncolor: 0 0 0.00
For. InProf : 2028 974815 0.07 <<<<<<<<< 7 Mb ? or 0.7 Mb ???? <<<<<<<<<<<<<<<
Ingress Queue 7 (Unicast) (Profile)
Off. ColorIn : 0 0 0.00
Off. ColorOut : 0 21 ~0.00
Egress Queue 2
For. InProf : 2215 1953656 0.15 <<<<<<< 30 Mb or 3 Mb ??? <<<<<<<<<<<<<<
Egress Queue 7
For. InProf : 0 21 ~0.00
thanks
For example,
100(e) up up
My question ;
Sap Statistics
Util.
Dropped : 0 0 0.00
Sap per Queue Stats
Util.
Egress Queue 2
Egress Queue 7
thanks
