hi
we have just got a lab OTBE with the dongle and the license. the factory installation was corrupt by me and some other engineer working here. the thing is that after few try outs i am able to install the OTBE fully with no problems, but when i run the oxevm and the vmManagement the parameters such as the ip addresses, dns names, server names are not the same as the values i have entered during the post installation procedure. i can re configure the vmoxe but its the windows server for the 8770 is the problem, when i modify the the server ip's and dns names i am not able to open the 8770 as its still trying to find the default dns as bics.company.com.
can any one help me in this one.
thanks...
OTBE 1.0 installation
Re: OTBE 1.0 installation
here are some captures i have taken during the post installation and of the vm 's
So from the documents!!!!! did u do this the first time after you start up windows???
7.2.2 vmManagement post installation
a. Via the Virtual Machine Manager connect the vmManagement
b. Open a Windows Explorer window
c. Execute (double click) C:\temp\postfactory\postfactory.vbs
The virtual machine is stopped.
d. Start vmManagement again by clicking RUN
e. After restart, you are prompted to connect to the system:
• Select the ice user and enter the default password (Sdfghjk1)
You are prompted to enter a new password.
• Enter a new password with:
• At least eight characters
• At least one upper case character
• At least one digit
oldboy...
once again you have saved my day. thanks alot. seems like i have done everything right all this time just missed these few details. now i am able to open 8770 and synchronize the oxe and the otbe. once again thank you very much.
morio
morio
