swkShow
- frank
swkShow
swkShow is a little tool that will show you the licenses / lock that you have on your PBX.
You can also compare 2 files. Useful if you want to see the difference between what you have now, and another file that your business partner sent you !
- tot3nkopf
Re: swkShow
It opens ok for me. Try using other application decompress it.wuchihhung wrote:swkShow Can't Open R8.x Swk ,Pls Check ! Thank You !!
Regards.
Re: swkShow
Can you explain a little bit how to use it?. I try to install, but I got and error during the installations I can not Install it.
Regards.
Regards.
Vsjakov_DUP
Re: swkShow
This program work without installation. You should use only file SwkShow.exe .
Maybe you have a bad arhive?
Re: swkShow
think swkshow don't work with R8 because R8 has 6 Bit and > 7.1 has 4 bit in OPS
Re: swkShow
Hello.
Can you explain how to used it?
Thakns.
AFLORES
Thakns.
AFLORES
Dave_DUP
Re: swkShow
Works great for me on releases under 8
Will not work on release 8
But it is a realy nice tool. Would like to see a new one
for the newer releases/
Miraculix01_DUP
Re: swkShow
I have made escataion on the R 8 issue to Alcatel R&D Team , the new tool from BPWS also not working with 6 digit R 8 swk Files !!
