Issues with ALEDS in New Installation
aflores
Post by aflores »
Hello frined.
I´m trying to intall (again) open touch but know it is with the ALEDS application.
All the procedure seem to be fine since there is no error during the procedure.
When everything is finished, the sistems runs the wizzard and also, everything seem to be fine. After finishing the wizzard the systems rebboots as should be.
The trouble is that, as son as the rebooting finished I got and error that says that the VMoxe and VMomnivista images were not found.
When I look at the VM manager, the VMoxe and VMomnivista are not pressent, are not installed.
I try again and again and I could see that during the installation procedure, the procedure installed the services as follow:
1° Linux.
2° Core
3° Fax server
4° TTS1 and TTS2 (since I only sellect just English and Spanish languages).
Them it reboots and start the wizzards.
Any help, I will appreciated.
Regards.
AFlores
aflores
Re: Issues with ALEDS in New Installation
Post by aflores »
I forgot some ussefull information.
Opentouch: R1.3 v000.71
ALEDS: 3.0.6.3
VMplayer: 6.0.2-1744117
My Laptop: Windows 7 Ultimate
aflores
Post by aflores »
Hello all.
Finally I realyzed that the trouble was caused because I downloaded a bad core iso image that did not belong to the v000.71, So be carefull when downloading the iso images
AFlores
Return to “OTBE - OpenTouch Business Edition”
