Problem: Report truncated to requested size
sitwaertsfahrer
Hi All
hope somebody can help me out with my problem.
I am creating reports, which I have to export to an other application so that the departments can be billed for there phonecosts. So the creating of the export works with no problems, but when I export the generated report to a *.xls or a *.txt it somehow truncates my report. Not all calls/costs are in the list and then the total cost isn't the same as the invoiced costs by the phone company.
Can somebody please tell me how to stop my reports beeing truncated.
Thank you very much.
btw: I'm using Alcatel Omnivista 3.2
Kind regards
simon
Kind regards
simon
torrentula
Re: Problem: Report truncated to requested size
There is an option for file size for each type of file you can save the reports as (xls,pdf,ect..).
I have not done this in awhile, can't remember where the option is.
Anyone know where to set the file size limits on 4760?
- tot3nkopf
Directory--->-->Reporting Tool
max limits in pages: 500 pdf, 1000 xls, 150 html
Regards.
Regards.
sitwaertsfahrer
Thank you very much
it works now
greetings
it works now
greetings
deax
What if I need more than max pages limit? My reports (pdf) are up to 700 pages.tot3nkopf wrote:Directory--->-->Reporting Tool
Regards.
Thanx.
gojj
Anyone know what to do if the maximum pages is already set and that it still truncates, for example XLS only allow '1000' in our version R4. This limit is probably there so that all the data including all text/pie chart and such would not expand beyond the 65k line limit?
I could of course export it to a text file and then import it into Excel. Is this the preferred way?
ettgo
did you try use a smaller font in the designer ? to have more data on a page....
luckyme2
exporting 1000 pages ? try better filtering because looking thru 1000 is s*.gojj wrote:Anyone know what to do if the maximum pages is already set and that it still truncates, for example XLS only allow '1000' in our version R4. This limit is probably there so that all the data including all text/pie chart and such would not expand beyond the 65k line limit?
Ocinesra
Hi!tot3nkopf wrote:Directory--->-->Reporting Tool
Regards.
I have the same problem written in the Subject of this thread. But i have not understand where i've to go to change this parameter.
I don't know very much this program, but i looked every menu in the Omnivista 4760 and i've not found this option.
Can someone explain in a simply mode where i've to go to change the size of reports?
Sorry for my bad english, i know that...
joao.carlos
Directory Application/System/Reporting Tool
