Dear All
Kindly Help Me to make Connection Between oxe crystal R 10 and teltronic IXP-CCS each Pbx Have E&M Cards
Mohamed Adel
How make Connection Between oxe crystal R 10 and teltronic?
Re: How make Connection Between oxe crystal R 10 and teltron
for Tetra use or what? why E&M use PRI E1 T2 Protocol.and mpt1343 dialing
i think you have to change some jumper in the emtl Board to put it working well
on oxe
create your board
creat trkgp with number , type LIA AND manage number of digits other parameter leave as default
afetrthat creat trunk under truk group that you have cretaed
give trunk equipement adrees :shelve -emtlboard position-terminal positiontrunk
give trunk cos (should be N °6 Assinged by oxe)
manage TRK cos parameters ACCORDING to other side under external services .
we'r in voip and sip world now
on oxe
create your board
bermawy
Dear Haroun
I Have PRI E1 T2 (NPRA Card ) What is Steps to make Connections between Teltronics Pbx By Configurations
thanks
thanks
OK
you should fixe those parametes before
Teltronics has same equivalent equipements ? E1 equipement
what's Protocol type -qsig , ISDNallcountries
teltonics is pbx not a Tetra equipement yes?
i expect it is for private use , without DID use
see oxe system doc under heterogenous network ,why i refer you to system doc because you have lot of parameterS to manage , board creation , cabling , , trunk group creation and protocol choice ,T2 acces creation and networking mode (SYNCHRO prio, TIELINE MODE YES/NO) managemnt DID TRANSCOd if used .
any way if oxe is master (networkmode) synchro =255 , and bChanal choice yes
