4760 license
mtcl
4760 license
Post by mtcl »
Could someone inform me if 4760 license version (R5.1) also supports 4760 R5.2 ?
Re: 4760 license
As it is a minor release yes
Zero
Re: 4760 license
Post by Zero »
Hello mtcl,
On a different perspective,
OV4760 R5.0 uses license release 11;
OV4760 R5.1 uses license release 12; and
OV4760 R5.2 uses license release 13.
However,
authorize licenses for OV4760 R5.0 are 10 & 11;
authorize licenses for OV4760 R5.1 are 11 & 12; and
authorize licenses for OV4760 R5.2 are 12 & 13.
-Zero
Re: 4760 license
Hummm interesting Zero. Thanks for the correction.
mtcl
Re: 4760 license
Post by mtcl »
Thank you for the information. I made the upgrade to 5.2 with license version 12 and it works fine !!
volcer
Re: 4760 license
Post by volcer »
thank you for this answer to this question
Return to “4760”
