6900 Active-Active configuration
firewall1981
Post by firewall1981 »
Dear Team,
I have two Omni switch 6900 and my client is asking to configure both the switch in Active-Active, please suggest how to do that...
Thanks in advance
Naaraj
benny
Re: 6900 Active-Active configuration
Post by benny »
Your customer wants a "Virtual Chassis" that allows to have link-aggregations across multiple elements of the VC running in active/active fashion.
You need to have the "Advanced" license on both the OS6900 for that.
B
firewall1981
Thnaks!!!!
Can you share me the configuration of load sharing
Naveen Dubey
benny
Post by benny »
Hi Naveen,
The following article has all the details to create a VC (actually two in that case), just build one of the sides. After that you only need to create a link-aggregation which is a piece of cake if you just review the documentation.
http://dokuwiki.alu4u.com/doku.php?id=e ... ack_vc-b2b
also read VC-related stuff here: http://dokuwiki.alu4u.com/doku.php?id=e ... al-chassis
B
Return to “OmniSwitch 6900”
