sipalarm.log - what means "has been removed from the denied"
tgn
Post by tgn »
Hello All,
i have this lines here in the "/tmpd/sipalarm.log".
> 07/22/14 - 16:27:46   Warning alarm
        [CConnection::dOSTest] Host:10.102.172.14 has been removed from the denied list
> 07/22/14 - 17:25:37   Warning alarm
But it is not clear to me what it means.
The IP-Adress 10.102.172.14 is a external sip gateway. The IP-Address is added to the "Trusted Addresses" in "mgr/SIP/Trusted Addresses".
So what means "has been removed from the denied list" ?
System is a OXE R11.0-k1.400-25-f
thanks and regards...
murraya
Re: sipalarm.log - what means "has been removed from the den
Post by murraya »
I see that message usually when sipmotor starts. its like the alarm is the system adding the trusted ip's.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
tgn
Post by tgn »
ok thanks... that can be a reason... my colleague has restarted the sipmotor this time...
regards...
Return to “SIP”
