wake on lan routing
alf
wake on lan routing
Post by alf »
Hello everybody!
Is there any possibility to route a Magic Packet WOL in an other VLAN?
The WOL Server is in VLAN 100 and the target PC is in VLAN 120.
Any ideas about that?
Thanks!
Alf
benny
Re: wake on lan routing
Post by benny »
Depends on how you send the WOL packets. You can work with ip directed-broadcast or UDP Relay services.
e.g. TT 6348
https://businessportal.alcatel-lucent.c ... =000010459
https://businessportal.alcatel-lucent.c ... =000010826
B
angelanavejas
Post by angelanavejas »
Hi benny can explain little bit about WOL packets.
samet
Post by samet »
maybe help you
Return to “Misc”
