Alcatel-Lucent 4018/IP - Only 2 menulines show
toro2222
Post by toro2222 »
Hi All
On one of the 4018´s only the first two lines of the menu show.
This makes the user unable to read messages (As thats item #3..)
This happened overnight, how can I enable the full menu ?
Tor-Olav
Re: Alcatel-Lucent 4018/IP - Only 2 menulines show
Check model in PBX. If model is incorrect will show number of lines according to the logical model and not the physical set.
Of course, first step is a reset before, right?
toro2222
Post by toro2222 »
Thank you, I shall test.
If this fails, how is the handset reset ?
Unplug/Plug
