problem edsbr command
Julio Cesar
Post by Julio Cesar »
Hello everyone
I'm trying to use the edsbr command to collect some information from my client, however the following information appears:
"(1) sesc_sete_lagoas > edsbr
1-dir-> Directory number
enter criteria or command: go
Query launched!
BACKTRACE (signal 11)
Please! Join this adresses with the * backtrace * * *
[/b]
(1) sesc_sete_lagoas > "
Could someone advise how I solve this failure?
ACSE OXE R9
ACSE OXE R10
giovanni.attolini
Re: problem edsbr command
Post by giovanni.attolini »
Julio Cesar, did you solve this problem? I have the same here.
tks
Giovanni A. Attolini
Do a dbcheck and then try to fix
giovanni.attolini
Cavagnaro, the same after a dbcheck. Any suggestions?
(101)callserver> checkdb
Data base checking in progress ...
(101)callserver> edsbr
 1 - act                                -> ACT shelf number
 2 - cpl                                -> Coupler number
 3 - pos                                -> Terminal number
 4 - dir                                -> Directory number
 5 - name                               -> Subscriber's Name
 6 - typ                                -> Station type
enter criteria or command:go
Query launched !
**** Please! Join this adresses with the backtrace ****
(101)callserver>
System:
R10.1.1 (j2.603.29b)
If memory doesn't fails me R10 has a bug in it. Try last patch
giovanni.attolini
I will update and post here the results.
Thanks Cavagnaro.
Julio Cesar
As Cavagnaro information, it is necessary to patch update for backtrace correction. In both R10 and R11 in.
ACSE OXE R9
ACSE OXE R10
KIKA
Post by KIKA »
Same problem with R11.0 ; K1.400.33
Return to “Usefull commands”
