8082 NOE to SIP ???
Split
8082 NOE to SIP ???
Post by Split »
Hi all
i have 2 8082 v1 one i used as 8082 NOE on OXE , the other one was not used until now. Now i want use both sets on OTBE. The 8082 that never used i have sucessfull update to the new binary with the ALEDS, but iam not able the switch back the 8082 NOE to SIP i try it with the ALEDS and i can see the DHCP Request but nothing happens. Can somebody help i think its a incorrct DM URL but not sure .....what the correct format für the DM URL in the 8082 i try https://@IP_OT/DM but nothing happens :(
I find some TC for the ALEDS but nothing what i have to do on 8082 side .....
Regards Split
oldboy
Re: 8082 NOE to SIP ???
Post by oldboy »
Step 2 you need to do a factory reset, step 2 again, need to change the running mode and then it should be all good, https://@IP_OT/dmictouch is the url if i remember correctly!
Split
Post by Split »
Hi oldboy
I try the URL but it did not work the set say switching to sip mode but after a few minutes the 8082 reboot furthermore i can not see any network traffic on the switch port led .....
Return to “MAIN”
