Trunk group
o75zaid
Trunk group
Post by o75zaid »
I would like to ask you what does means (hs) that appear when I type command trkstat
thanks
| T R U N K S T A T E - APA 8 Coupler Crystal_nbr = 7 |
| IN SERVICE Coupler Nbr = 6 |
| Trunk Grp 116 110 110 110 113 113 113 113 |
| State B B B F F F F hs |
Re: Trunk group
Out of service.
o75zaid
Re: Trunk group
Post by o75zaid »
I have checked the trunk line but found it connected to the pbx
Re: Trunk group
hs still...cable broken, short circuit, voltages variating, etc. You have to do a proper discard and not just look a cable connected...
o75zaid
Re: Trunk group
Post by o75zaid »
I would like to thank you , the problem has been solved but there is other thing that some trunk lines I found them Busy by using the command trkstat when I checked them from the main MDF I found the line is open but it is not used. when I disconnected the cable that is connected to the PBX ,the line is working normal .
Re: Trunk group
reset the equipement or the whole interface board
Re: Trunk group
and plugin correctly the board
o75zaid
Re: Trunk group
Post by o75zaid »
Thank you haroun, I have done reset and it is ok now.
Return to “Trunk Groups”
