Problem between oxe and mitel pbx
edylor2580
Post by edylor2580 »
Good night, everybody, my problem is that I have a link between oxe and mitel pbx (ISDN), it works fine I can call between them, but I have my PSTN external lines (analogs) in the OXE, but I want to use those lines from the mitel 3300, and I can´t; a t3 command said:
| (483292:000012) Physical-Event :
| long: 87 desti: 0 source: 0 cryst: 0 cpl: 9 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 38
| SENDING COMPLETE
|______________________________________________________________________________
| IE:[18] CHANNEL (l=3) a9 83 9f -> T2 : B channel 31 exclusive
| IE:[1c] FACILITY (l=35)
| [91] Discriminator of supplementary service applications
| [aa] NFE (l=6):
| [80] Source Entity (l=1) End_PTNX
| [82] Destination Entity (l=1) End_PTNX
| [8b] Interpretation APDU (l=1): DISCARD (0)
| [a1] INVOKE (l=21):
| Invoke Ident. : 005b (91)
| OP: ECMA RO_CALLING_NAME (0)
| [30] Sequence (l=10)
| [80] Name presentation allowed (l=8) '1.bodega'
| [80] Context specific (l=8)
| IE:[6c] CALLING_NUMBER (l=6) -> 09 80 Num : 3011
| IE:[70] CALLED_NUMBER (l=7) -> 80 Num : 520026
| IE:[7d] HLC (l=2) 91 81
| (483292:000014) 1886: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 0 cpl: 9 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : STATUS [7d] Call ref : 80 38
| IE:[08] CAUSE (l=3) 80 e3 1c -> [e3]
| INFORMATION ELEMENT NON-EXISTENT OR NOT IMPLEMENTED
| IE:[14] CALL_STATE (l=1) 06
| (483292:000015) 1886: Send_IO1 (link-nbr=9, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 0 cpl: 9 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 38
| IE:[08] CAUSE (l=2) 80 82 -> [82] NO ROUTE TO SPECIFIED TRANSIT NETWORK
the number 3011 is the extension calling, 5200 is the prefix to take the trunk and 26 is the extension.
I have seen some people solved this problem, can you help me with this .
Thank you
Re: Problem between oxe and mitel pbx
IS IT TRANSIT allowed
e1 trunkgroup PNC =?
isdn trunk connection cos =5 shhould be authorised to connect with pstn analog trunk C onnetion cos (see this under connection class of service)
And DID transcoding for incoming TG.
oldboy
Post by oldboy »
So if you dial 520026 from another extn on the OXE does it reach the destination??
by the way, stronge called number under pstn
you external pstn line witch mean public network and you call 26 as extension , is it Abbreviated number ?
public networks allow for regular subscriber at least 6 digits AB MCDU -for some country if you'r in same area and carrie you can use 4 digit-
edylor2580
Thanks everybody, I solved the problem like another people had done, I created TG 0 and added trunk lines, then I created a prefix 0 to adquire TG 0 in OXE, then in Mitel i created prefix 0 to get the TG 0 from OXE, and it worked.
Thanks.
Dav1d
Post by Dav1d »
Do you hava documentation how to make a (SIP Trunk) link between oxe and mitel pbx (3300 CX)?
at this moment , i Don't think there's an IWR for that scenario, but u can setuo it as a standard sip trunking solution
do you have necessary licenes ?
see system doc for configuration model (private or public sip trunking)
Dav1d
Post by Dav1d »
haroun wrote: 10 Jan 2022 04:10 Hi
Thanks for your awnser.
I have the necessary licences.
I will have a look into the configuration files for the Mitel 3300 CX and the Alcatel OXO
Your Alcatel box is OXO or OXE ?
if it's an Oxe give it a try (config and so on ) and if u need help do not hesitate by creating a new topic
just follow system doc oxe Rx /ip/sip/siptrunckin it should not be a big deal
Return to “Trunk Groups”
