No ethernet on hard drive
philasphe
I cannot access an OXE via ethernet, only the V24 works. I changed the CPU7-2, shelf, connection box and cables and still things don't work. Now i suspect the HDD but unfortunately i don't have a recent backup. Any idea on what the problem is or how can i obtain the backup any other way with FTP not working?
GTM
GTM
Re: No ethernet on hard drive
if i'm not wrong you can use hyperteminal or other zmodem to do this , search also for kermit or (gkermit) in the formun may be it can help
also try uhwconf command to see if ether is presente
The main problem with Ethernet connection was (if Ethernet not works from the beginning) - when you connect Ethernet cable to the backplane you connect to wrong position (the first pin must be 17). If you connect look to "Ethernet" label - first pin may be wrong (18)
philasphe
On the same unit, i used a different CPU7-2 and HDD it works. If only i had the most recent backup, i would be preparing the new working HDD. The PINS on the backplane are ruled out here. What i want to do here is retrieve the backup and OPS keys from this HDD but ethernet is on strike. Serial connections work fine but i cannot run FTP.
connected with v24 i tape
(1)pst_cpu6> clear
(1)pst_cpu6> gkermit
G-Kermit CU-1.00, Columbia University, 1999-12-25: POSIX.
Usage: gkermit [ options ]
Options:
-r Receive files
-s fn Send files
-g fn Get files from server
-a fn As-name for single file
-i Image (binary) mode transfer
-T Text mode transfer
-P Path/filename conversion disabled
-w Write over existing files with same name
-K Keep incompletely received files
-p x Parity: x = o[dd],e[ven],m[ark],s[pace],n[one]
-e n Receive packet-length (40-9000)
-b n Timeout (sec, 0 = none)
-x Force Xon/Xoff (--x = Don't force Xon/Xoff)
-S Disable streaming
-X External protocol
-q Quiet (suppress messages)
-d [fn] Debug to ./debug.log [or specified file]
-h Help (this message)
More info: http://www.columbia.edu/kermit/ <kermit@columbia.edu>
(1)pst_cpu6>
(1)pst_cpu6> clear
Options:
-r Receive files
-s fn Send files
(1)pst_cpu6>
If you have another CPU/HDD - where Ethernet works. Just install HDD to working CPU and save backup.
philasphe
Haroun -i don't get you brother, i doubt you are trying to help me
Vad - Tried that and that is where i realised that the problem is with the HDD and to make it worse i have no recent backup. No IP metering and IP phones.
XD so showing you the command with options and saying already what to do, is not helping you? Then what? You expect him to go and type the commands for you? Move your hand too???
You are a quite funny guy
rofl...
sry i must ask this question.
if gkermit is too much complicated to you and ethernet is not possible... but you are able too take a screwdriver to install the harddisc to another cpu7-2... WHY don't just connect the harddisc with an usb adapter to another computer. even for windows os there are drivers for reading data from ext2 partitions...
regards...
rofl...
regards...
If you have problem with HDD and you want to retrieve backup (not sure, depends of HDD errors) - for me more right way:
- use laptop with Linux
- connect HDD with USB adapter
- mount HDD and try to save partition with database (/usr3/mao, usr4/BACKUP)
