ip touch 4038 - problem with certificate download
marc_bo
I'm new at the forum and from Germany so please excuse my bad english.
I have to set up network access control in our company. And my Problem is to get the certificates automaticly to the IP touch 4038.
I set up the lanpbx.cfg like this:
CERTSRV_IP=10.15.3.20 CERTSRV_PORT=80 CERTSRV_PATH=/certserv
The certificate is at the folder /certserv like this: "macaddress-ip-phone".pfx
When the IPphone boots up, I have the following steps:
1/5network start
2/5 network setup
3/5 config download
bad file content
5/5 connecting
connected
Hope anybody can help me!!
kind regards
Marc
1/5network start
2/5 network setup
3/5 config download
bad file content
5/5 connecting
connected
kind regards
Marc
- frank
Re: ip touch 4038 - problem with certificate download
So your lanpbx.cfg looks kind of like this:
TYPE=A4400 VERSION=1 IP_DOWNLOAD=192.168.1.120 IP_CPU1=192.168.1.120
CERTSRV_IP=1.2.3.4 CERTSRV_PORT=80 CERTSRV_PATH=/certsrvCode Free Or Die
marc_bo
my lanpbx.cfg first looks like this:
Now I fixed like this:
Now I can see no bad file error. But my certificate will not be downloaded automaticly.
CERTSRV_IP=10.1.3.2 CERTSRV_PORT=80 CERTSRV_PATH=/certserv
TYPE=A4400 VERSION=1 IP_DOWNLOAD=10.1.2.3 IP_CPU1=10.1.2.4 IP_CPU2=10.1.2.5
- tot3nkopf
Which is the type of access required by the web server? (anonymous or basic?)
Did you configured the access user and password on IP Touch? (default user is ALCIPT and no password is configured by default)
marc_bo
In my test I use Apache (XAMPP) and in the conf is the basic access loaded:
LoadModule auth_basic_module modules/mod_auth_basic.so
#LoadModule authn_anon_module modules/mod_authn_anon.so
Should I try with anonymous?
There are no credentials configured, I use the standard user ALCIPT without a password.
Additional Information:
I tried with a certificate with password and one without.
I can download the certificate manually on the IP touch Phone "Menu\Certificate\Get Certificate".
When i go to the get certificate menu i see my IP parameters, which I set in my lanpbx.cfg...
- frank
I would say try with anonymous
marc_bo
I tried but no changes...
The thing is, when i start the download manually it works!
Then probably the certificate format is not correct?
- tot3nkopf
You need to activate manually the certificate... (at least in my understanding from what I have read in the docs) I do not think this can work automatically...Raise an eSR and ask ALU if this is the case and maybe open a feature req for an automated process...marc_bo wrote:I tried but no changes...
Funny is that we need to do the same tests here..
- tot3nkopf
Manually it is working....cavagnaro wrote:Then probably the certificate format is not correct?
