Calling and Called Name display On H323 Trunk
Rtotrfab
Post by Rtotrfab »
Hello Everybody
I have a problem please
I set up a H323 trunk between An OmniPCx Enterprise R10 an an OmniPcx Office R8.Calls are Succesful in the two ways, but my problem is that i want to display the calling Number on the Set connected to the OmniPCX Enterprise.
How can i do it (is it possible to send the Calling Number from OXO)
Thank you for your replies
Re: Calling and Called Name display On H323 Trunk
Check with "t3" trace - present or not Calling Number (Calling Name) in SETUP message.
If present - you need to manage OmniPCX Enterprise (f.e. Translator/ Ext. dialing plan - Ext. callback tanslation - create at least string DEF-0)
Rtotrfab
Post by Rtotrfab »
Hello.on the t3 trace the calling name is not there.
Rtotrfab
Post by Rtotrfab »
Hello EveryBody,How are you?
Concerning the display of the calling name, do you know a parameter to change on OmpiPCX Office to send the Calling Name on the H323 Trunk?
Because when i look at the "t3" trace on OXE while calling from OXO, The calling Name is not displayed.
Thank you.
From your post "but my problem is that i want to display the calling Number on the Set connected to the OmniPCX Enterprise", "is it possible to send the Calling Number from OXO".
I think your have problem with NUMBER. If you have problem with NAME from OXO - this is another story.
