Out of TCAM processors on 0/1 (0)
phathienhung
Post by phathienhung »
When I set a policy command on Omni 6900, it appears error : Out of TCAM processors on 0/1 (0). I've search the error on this site and get this link https://service.esd.alcatel-lucent.com/ ... umber=3728, but I can't access that link. Anybody help me the solution ? Thanks in advance.
devnull
Re: Out of TCAM processors on 0/1 (0)
Post by devnull »
How many policys do you have?
What code are you using?
I have found two Techtips, one for 6450 where a bug is fixed with 6.6.4.264 and another for 6900 where more than the allowed 1024 silces where used.
Open a SR if you are unsure.
phathienhung
I've deleted some entries of policy and it doesn't appear error : Out of TCAM. But when I do write memory, it appears another error :
Write Memory failed! Unable to retrieve LFP configuration.
Sat Jan 10 22:45:23 : ConfigManager SNAP warning message:
+++ Snapshot failed. (error = -5)
What should I do to fix this error ? Thanks in advance.
devnull
Post by devnull »
No Idea..
do an upgrade to the latest version open a SR
Return to “OmniSwitch 6900”
