interface down in VPRN service
hc98014
Post by hc98014 »
Hi guys,
anyone knows about the meaning of this log ?
*A:7750sr# show router 35 interface "test"
Interface Table (Service: 35)
Interface-Name Adm Opr(v4/v6) Mode Port/SapId
IP-Address PfxState
vocus_intnl Up Down/Down VPRN 1/4/3:761
1.1.1.1/30 n/a
Interfaces : 1
*A:mt-akq-bng1#
*A:7750SR# show router 35 interface detail
Interface
If Name : test
Admin State : Up Oper (v4/v6) : Down/Down
Down Reason Code : ifAdminDown
Protocols : None
IP Addr/mask : 1.1.1.1/30 Address Type : Primary
IGP Inhibit : Disabled Broadcast Address : Host-ones
HoldUp-Time : 0 Track Srrp Inst : 0
gargoyle
Re: interface down in VPRN service
Post by gargoyle »
AFAIK, Ifadmindown means that you not enable the interface (shutdown),
Interface Table (Service: 111)
Interface
If Name : to_test
Admin State : Down Oper (v4/v6) : Down/--
Protocols : None
IP Addr/mask : 10.10.10.10/30 Address Type : Primary
it little bit strange that you had enable the interface but the notifcation IfAdminDown still persists,
maybe you should try to shut/no shut the interface?
hc98014
Post by hc98014 »
I've already done shut/noshut couple of times.
actually, it worked fine first time but i have got some problem in our system (i guess memory problem),then I rebooted system.
after that interface does not come up.
it is strange that it only took about 1min 30 seconds completed reboot with the command admin reboot now.
I just tried to have same topology by using gns3 simulator. it happened again.
any body has idea for that?
rekeds
Post by rekeds »
route-distinguisher configured?
Return to “7750 SR”
