Transfer external incoming call between 2 interconnected oxo
jalloulj
Post by jalloulj »
Hello everybody,
Well, like said in the title, I would like to know if it's possible to transfer an external incoming call from site A to an internal set on site B, assuming that both sites are equipped with two identical Oxo with 2 voip cards on each powerCpu and all the necessary licenses and configuration is made (I mean both oxo will be interconnected)
I need to know this so the customer who owns both sites is sure that he can manage all incoming external calls with only one operator on site A (he doesn't have an operator on site B).
Maulwurf
Re: Transfer external incoming call between 2 interconnected
Post by Maulwurf »
yes
jalloulj
Post by jalloulj »
Thanks for the quick reply.
I asked this question because I have already a customer with 2 interconnected oxo via voip and this feature never worked for him.
Maybe there are some parameters I forgot to configure so that I can get this option to work.
Any help please!
Maulwurf
Post by Maulwurf »
Maybe? I think so ;-)
You have to check a lot of parameters.
First try feature design part 2 transfer ext/ext an if you want by onhook.
jalloulj
Post by jalloulj »
Hi Maulwurf,
Well the parameters you indicated were all right.
What I missed was the joining matrix under the Traffic sharing and barring!
I ticked the right squares and it's ok.
One last question: is it possible to make external trunks connected physically to site B ring on the operator set located in site A?
Thanks and have a nice day.
simple transit case , if transit is allowed and destination is known by the connection site why should it not work ?
Return to “Networking”
