call disconnected randomly
marlon74ph
Post by marlon74ph »
Our client has OXO 5.1
1. calls are disconnected randomly at any extension between 1-2min for external and internal calls, does anybody encountered this problem?
Re: call disconnected randomly
Any traces in history of anomalies?
marlon74ph
date time event explanation phys addr
08/05 4:49: 15pm 112 device prob 01-07
08/05 4:49: 19pm 110 device accepted 01-07
Maybe you have a problem with new software downloading into terminals? Try using Data Saving and swapping--->Terminal downloading and see if there is any change. If not get the last R.5 software release from BPS and download it into your PBX and make a swap with data saving.
Regards.
Jigger
Post by Jigger »
Get the system earth, and reading under 1 ohm.
Alot of site's i work at had call drop outs untill i had them do this, now its all good.
Return to “MAIN”
