OXE 4400 + IP Touch 4018
gurioste
Post by gurioste »
Gurus,
I have a situation where I need to register new extensions (IP Touch 4018 phones) on an OXE 4400 (v10).
Whenever I try to create a new extension via Omnivista, I get the following error (the interface is set to Spanish):
> Crear \xa000001\Abonado::4283
Bloq. 316/317(usua. estánd.): error protección soft.
I pulled the "Active file" information on telnet (spadmin > Display active file (option #2) and this is what it had among other lines:
316 M Standard Reflexes users = 0/0
317 M Standard IP users = 169/0
318 XML IPTouch-IP engine = 0
175 M Mobile users = 0/0
176 M Advanced IP users = 1/170
Here's the entire file in case anyone wants to check it out: http://tinyurl.com/o5sy3vq
I thought that having Advanced IP users would be enough to register new extensions with 4018's, but it seems like these phones either don't go under "advanced" or something else is missing.
Would anyone be able to throw some light into my question?
Thanks in advance,
G
tgn
Re: OXE 4400 + IP Touch 4018
Post by tgn »
if you have advanced ip users license than you can allways use this licenses to install normal ip users. but take into account that you have to summarize the output in spadmin to discover the used licenses.
regards...
gurioste
Post by gurioste »
Thanks for your response @tgn.
Could you explain how I do to summarize the spadmin output?
Thanks,
G
tgn
Post by tgn »
for summarize you have to use the "+" sign between the two numbers. never use the "-", "*" or "/" !
^^ just kidding ^^
just take the sum of the lines:
  176 M Advanced IP users                   =       0/   142
  317 M Standard IP users                   =       1/     0
in this example 1 standard ip user is in database programmed and 142 advanced and standard ip users are possible.
regards...88
I never understood what is the difference between that "Advanced" vs "Standard", do you know?
gurioste
Post by gurioste »
tgn wrote:for summarize you have to use the "+" sign between the two numbers. never use the "-", "*" or "/" !
^^ just kidding ^^
regards...88
Thank you @tgn again for the explanation.
And I might be asking a pretty dumb question again, but shouldn't I have available slots given the information I shared? Maybe I did not understand how the sum has to be done....
Is it 169 + 1 = 170 meaning I have 170 out of 170 slots used? And no more slots are available :) ?
Thank you,
G
That is correct and reason why you have that error when trying to create user 171
tgn
Post by tgn »
hi cav,
difference between srandard and advanced is level of assigned multilines and the corresponding features , a subscriber set is advanced, if it has more than one multiline.
regards...
Just that? Cool!
Thanks a lot!
gurioste
Post by gurioste »
Thanks a lot tgn!
Cheers!
G
Return to “System”
