Good Morning
We have a EOX 4400 R10, 175 IPTouch licenses with 4760
We want to increase our IP licenses to be 200 (for New telephone to install).
we are forced to change the 4760 in 8770?
We are forced to migrate from R10 to R11.1?
What are the advantages and disadvantage of staying on as the R10 with 4760 IP Console for 200 licenses (Posts IPTouch)
Thank you for your answers
IP License increase
- Konstantinos.E
Re: IP License increase
No, for add on in 4760 is still posible with out upgrading anything.
NEW installations canot be done.
R11.1 has varius of improvements-add ons but you need to read TC witch i dont remember.
If your system Works ok and you dont need to make major changes then you can stay in r10 is still supported be alcatel-lucent
Alca_holic
got
is that the 4760 will still exist for the new versions?
R11 or R11.1 can work with 4760
What are the major improvement that we find on the 8770 R11or R11.1 , that are not found on the R10. ?
4760 is faced out, no new implementations as said.
Already answered, you need to check TC or ask your BP who is selling it to you what are the advantages for your implementation, #1 will be SUPPORT, with new version you have SUPPORT.
