SIP Trunk CISCO VCS to OXE Alcatel
mokhtar ACFE
I have probleme in SIP Trunking OXE , incomming call from CISCO VCS ( vedeo call Srver) doesn't work .
but when I do the call from OXE by dialing 884012 work fine .
in attached the tow trace SIP , one ork fine but the othet doesn't."CIsco VCS to OXE.tx".
can any one help me please .
best reagrds
best reagrds
karthikeyan
Re: SIP Trunk CISCO VCS to OXE Alcatel
Do you have redundancy server?
Try to manage IP domain.
hi mokhtar
lol are you using public domains man ! "gsa.dz"
look at to this 1425573192 -> 110e [CProxyCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1425573192 -> [CGwMngData::isAuthenticationRequiredForThisClient] gsa.dz .
1425573192 -> [isDomainFromGwExt] Host from request is : gsa.dz.
1425573192 -> [isDomainFromGwExt] User from request is : !?! UH !?! You shouldn't read this.
SIP/2.0 404 Not Found
To: <sip:874712@gsa.dz>
From: "Mokhtar Belkhiati" <sip:dzhc0078@gsa.dz>;tag=7ab2a0c6c7515a5f
Call-ID: c7f891fcbd7e784c@10.178.17.96
try to use @ip adresses instead of fqdn
another question
what's 87 in 874712: is it prefix to seize the sip trunk ? if it's the case so you have to remove it
mokhtar ACFE
yes I have redundancy server .karthikeyan wrote:Do you have redundancy server?
how to manage IP domain ?
mokhtar ACFE
I d'ont think I created a new extention with the N° 874712.haroun wrote:another question
sure mokhtar
so oxe response by 404
mokhtar ACFE
Your system has the private network number 0 and the site number 1.
Private IP addressing space: no
Restricted internet accesses: no
Accept ICMP redirect: no
Low dynamic ports range configuration : 10000 - 10499
There is no VLan configuration. No frame will be 802.1q-tagged.
The ethernet redundancy is not supported on this CPU type
node name : gsabrn
internal name resolver activated : no
Ethernet interface setup
Netmask : 255.255.255.192
| Machine type | Local interface | Name | Address |
| local | Ethernet | cs_8 | 10.178.17.200 |
| local main | Ethernet | xm000001 | 10.178.17.202 |
| router | Ethernet | routerbrn | 10.178.17.193 |
| local | IP/X25 tunnel | x000001_tun | 172.30.253.1 |
node name : gsabrn
