Display Name Only
majid2236
Display Name Only
Post by majid2236 »
Dear All
problem:
consider two users (A and B). when user A call user B, user B receive phone number and name of user A but I want to configure my system that user B can only see user A name (not name and number). how can I do it ?
I don't think that is possible... Why would you hide which extension is calling? How would he callback for example?
Re: Display Name Only
Try - user B phone feature COS - item Virtual set on CMP board (not remember - you will see or only name, or only number).
Hey Vad but doesn't that worked only with CMP boards? I do remember that for remote agents for example...
Not find in my documents (and absent PBX for testing) - but as I remember- this item works for usual digital or IP sets.
system parameter display only name (caller /called ) works only after call answred
specific tel serv dispaly mode of callid ..... called party name may be you have to play with user cos in this case
sunder.J
Post by sunder.J »
I'm facing a problem where only the number is being displayed but name is not getting displayed. I have managed under specific telephone services as below
Display mode of call ID + calling No => Called Name
still I'm not getting the called / caller name in the IP phones
sunder.J
Post by sunder.J »
I have 4038 & 4068 IP touch in site
Try to change it to Display mode of call id. + Calling No => Called Name
sorry usualy done
Return to “Users”
