ARS issue on Private to Public overflow
soilun
Hi all,
My topology have Twin CPUs, 2 PCS for rescue IP Client when the Twin down. When Twin down, client be rescued by PCS still reach each other via ISDN on Media GW. So I configured feature "Private to Public Overflow between IP Media Gateways". Detail configuration as below:
++++++Node DID Translation++++++
"This is for Domain 1"
x Node Number (reserved) : 1
x Instance (reserved) : 1
x Destination Node No. : 1
x First External Number : 3411111
x
x First Internal Number : 1001
x Range Size : 100
x Unique Internal Number + NO
x Thin Sector + YES
"This is for Domain 2"
x First External Number : 3411112
x
x First Internal Number : 2001
x Range Size : 100
x Thin Sector + YES
++++++Entity Discriminator Selector++++++
x Entity Number : 6
x
x Discriminator 00 : 0
x Discriminator 01 : 0
x Discriminator 02 : 2
x Discriminator 03 : 0
x Discriminator 04 : 0
x Discriminator 05 : 0
x Discriminator 06 : 0
x Discriminator 07 : 0
++++++ARS Prefix Plan++++++
x Number : 6
x
x Prefix Meaning + ARS Prof.Trg Grp Seizure
x Discriminator No. : 2
++++++Discriminator Rule++++++
x Call Number : 3411111
x
x Area Number : 1
x ARS Route List Number : 1
x Schedule Number : -1
x Number of Digits : 255
x Call Number : 3411112
x
x Area Number : 1
x ARS Route List Number : 2
++++++ARS Route++++++
x ARS Route list : 1
x Route : 1
x
x Name : 2D2
x Trunk Group Source + Route
x Trunk Group : 11
x No.Digits To Be Removed : 0
x Digits To Add : ------------------------------
x Numbering Command Tabl. ID : 0
x VPN Cost Limit : 0
x Protocol Type + Dependant on Trunk Group Type
x NPD identifier : 255
x Route Type + Public
x ATM Address ID : -1
x Preempter + False
x
x Quality
x
x [ Add ] [ Remove ] [ Next ] [Previous]
x
x Quality + Speech
x ARS Route list : 2
x Route : 1
x
x Name : 2D1
x Trunk Group : 10
x Preempter + False
x
x Quality
x
x
x Quality + Speech
When I make a test by turn off Twin CPUs, client can make local call in their Domain, make call to PSTN via ISDN. But when I dial from Domain 1 to Domain 2 (Example, from 1001 dial to 2001) the client screen show external number of Domain 2 (In this case is 3411112) and after that, it show "Feature rejected".
What is this error? Am I wrong during configuration. Please give advices
Thank you very much
x
x Range Size : 100
x Thin Sector + YES
x
x Range Size : 100
x Thin Sector + YES
x Entity Number : 6
x
x Number : 6
x
x
x Area Number : 1
x
x Area Number : 1
x Route : 1
x
x Name : 2D2
x Trunk Group : 11
x Preempter + False
x
x Quality
x
x
x Quality + Speech
x Route : 1
x
x Name : 2D1
x Trunk Group : 10
x Preempter + False
x
x Quality
x
x
x Quality + Speech
Thank you very much
- tot3nkopf
Re: ARS issue on Private to Public overflow
User needs private to public overflow right in phone features category.
soilun
Dear tot3nkopf,tot3nkopf wrote:User needs private to public overflow right in phone features category.
Thank for your reply, I think I already configured. Please check the configuration below
x Phone Features COS : 0
x
x Phone COS Name : --------------------
x
x Rights
x
x Prot.against dir.call pickup : 0
x Protected against all barge-in : 0
x Protected against set barge-in : 0
x Outgoing calls only : 0
x Forward to external No. : 1
x Prot.against multi-l ringing : 0
x Protected against forwarding : 0
x Protected (against barge-in, etc.) : 0
x Prot.against call announc. : 0
x Remote wake-up/appointment : 0
x Auto call back on busy trk-grp : 0
x Transfer on no answer : 1
x ISDN remote charge service : 0
x Bypass on forwarding : 0
x Prot.against bypass onforward : 0
x Interphony : 1
x Secret Code, Repertory Key : 0
x Night Serv.Answ.Pick up : 0
x Night Serv.Direct call pick-up : 0
x Attendant Call Privil.on PAI : 0
x Busy priv.to public overfl. : 1
x Server-Minitel PC : 0
x Prot.against Priv.Call : 0
x Prot.against.Rem.Forward. : 0
x Beep On Ext.Call : 0
x O/S private to public overflow : 1
x Transfer outgoing - incoming : 0
x Transfer Outgoing-Outgoing : 0
x PCX Calls Follow Ext. forwarding : 1
x Mask ID.name Only for ext.calls : 1
x Ringing tone In Handset : 1
x No Text Msg reception : 0
May be ars privilege and vpn cost limit are insufficient
soilun
Dear haroun,haroun wrote:May be ars privilege and vpn cost limit are insufficient
Here after is my Access COS for all IP Client
x ARS privilege x
x x
x Night : 1 x
x Day : 1 x
x Mode 1 : 1 x
x Mode 2 : 1 x
x x
x VPN Cost Limit x
x x
x Night : -1 x
x Day : -1 x
x Mode 1 : -1 x
x Mode 2 : -1
ARS privilege x
x x
x Night :0 x
x Day : 0 x
x Mode 1 : 0x
x Mode 2 : 0 x
x x
x x
x Night :0 x
x Day : 0 x
x Mode 1 : 0x
x Mode 2 : 0 x
x x
soilun
Dear haroun,haroun wrote:ARS privilege x
x x
x Night :0 x
x Day : 0 x
x Mode 1 : 0x
x Mode 2 : 0 x
x x
I've just test with this, same problem
soilun
Hi all,
I tried to configured ARS feature, and met same proplem "Feature rejected". Is there any COS I need to activate to use ARS feature?
hi
past the time based rout list
hi
past the time based rout list under ARS route list/1 & 2
