I have problem. I forgot my password and ı try to reset the password. Frist J343 and connect pin 1+2 with a jumper.
And ı try this steps
Stop boot seq with Y
type Y to enter VxWorks boot
c to enter config
and ı press enter four time and ı see the password than ı gave up being reset password.
ı write reboot end hit the enter but now consol is not responding. I have 2 cmm card and ı tried these steps on both cards.
Now only 1 card responds but its not openning. How ı can fix this. Please help me
usrInit(): Entered with startType=0x82 (COLD) (w/ POWER ON RESET)
usrInit(): Current BBUS FPGA Revision=44 (0x002C)
usrRoot(): COLD Boot.
Checksumming 'default' miniboot... Done.
Uncompressing miniboot image... Done.
Starting at 0x500000...
Identified 32 MB of AMD Flash media.
Flash file system already installed.
Intializing the flash file system. Please wait...
Flash file system initialization complete.
The current date and time is:
Coordinated Universal Time (UTC): WED APR 07 06:25:38 2021
Local time: WED APR 07 09:25:38 2021 EEST
/flash/ - disk check in progress ...
/flash/ - Volume is OK
total # of clusters: 14,773
# of free clusters: 1,438
# of bad clusters: 0
total free space: 2,876 Kb
max contiguous free space: 780,288 bytes
# of files: 71
# of folders: 5
total bytes in files: 26,587 Kb
# of lost chains: 0
total bytes in lost chains: 0
Error in boot line:
(0,0) e=192.168.1.1:ffffff00 g=192.168.1.254 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff
asciiBootParamsInitialize() failed.
Error initializing boot parameters.
Boot parameters are:
'(0,0) e=192.168.1.1:ffffff00 g=192.168.1.254 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
Adding 4062 symbols for standalone.
AOS miniboot version: 5.1.5.340.R01
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/Fos.img'...
3420784
Starting at 0x40000...
Coordinated Universal Time (UTC): WED APR 07 06:25:41 2021
Local time: WED APR 07 09:25:41 2021 EEST
Error in boot line:
Error in boot line:
Adding 5254 symbols for standalone.
0x75ffd50 (tRootTask): panic: rn_init
): AOS kernel panic: version: rn_i5.1.5.268.R04nit 2
VxWorks (for CMM (Sparc-V9)/400) version 5.4
KERNEL: WIND version 2.5
Made on Mar 23 2006, 18:04:52.
Copyright Wind River Systems, Inc., 1984-2000
CPU: CMM (Sparc-V9)/400. Processor #0.
Memory Size: 0x7600000 (118 MB). BSP version 1.0/0.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2003. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
WDB: Ready.NVRAM boot parameters are out-of-sync with '/flash/boot.params'.
NVRAM boot parameters were updated using '/flash/boot.params'.
Starting dynamic software load from '/flash/certified/'...
Error setting inet address of ipc0 to 127.1.65.0, errno = 0x3d0001
sysStartWatchdog() Starting watchdog timer to INTERRUPT after 60 secs.
WED APR 07 09:25:47 : SYSTEM (75) info message:
+++ Switch Logging device '/dev/console' enabled for output
WED APR 07 09:25:47 : CSM-CHASSIS (103) info message:
+++ === Chassis Supervision Starting Up ===
Error in boot line:
+++ The certified version is used
+++ MONITORING ON
+++ This CMM is primary
WED APR 07 09:25:48 : PRB-CHASSIS (102) alert message:
+++ Fan #1 Failure!!
+++ Fan #2 Failure!!
+++ Fan #3 Failure!!
WED APR 07 09:25:48 : HSM-CHASSIS (101) info message:
+++ T1:Ni Insertion detected on slot 1
+++ T1:Ni Insertion detected on slot 2
+++ T1:Ni Insertion detected on slot 6
WED APR 07 09:25:49 : HSM-CHASSIS (101) info message:
+++ T1:Ni Insertion detected on slot 9
+++ T1:Ni Insertion detected on slot 10
+++ T1:Ni Insertion detected on slot 11
+++ T1:Ni Insertion detected on slot 14
+++ T1:Ni Insertion detected on slot 15
+++ T1:Ni Insertion detected on slot 16
Error accessing /flash/working/Fwebsecu.img . errno = 0x27100002
WED APR 07 09:25:51 : HSM-CHASSIS (101) info message:
+++ === HSM === Power Supply 2 is OPERATIONAL
Exception: Data Access Exception
Excepprogram counter: 0x05c4ff24
tionnext program counter: 0x05c4ff28
: Data Accepstate: 0x0000001e
fsr: 0x000000030f400820
ss Exceptaccess address: 0x25e4c33c
Task: 0x5e4c4b0 "SNMP GTW"
WED APR 07 09:25:54 : SYSTEM trap message:
Task 0x5e4c4b0 (SNMP GTW) priority 100. trapped
11a4c0 vxTaskEntry+c : snmp_udp_gtw(0, 0, 0, 0, 0, 0) fp=5e4c3d0
%pc = 5c4ff24 %npc = 5c4ff28 %ccr = 44 %y = 0
%asi = 0 %cwp = 6 %tt = 30 %tl = 1
%pil = 0 %pstate = 1e
%g0 = 0 %g1 = f %g2 = 0
%g3 = 0 %g4 = 0 %g5 = 0
%g6 = aad660 %g7 = dbdadeebff293c5b %i0 = 0
%i1 = 0 %i2 = 0 %i3 = 0
%i4 = 0 %i5 = 0 %fp = 5e4c3d0
%i7 = 11a4c0 %l0 = 7ffffff %l1 = 6d180a0
%l2 = 682ef68 %l3 = 6d23568 %l4 = 400001
%l5 = 6d18000 %l6 = 67ed000 %l7 = 3006c
%o0 = 1ffffffc %o1 = 5e4c340 %o2 = 1ffffffc
%o3 = 5e4c340 %o4 = 80000000 %o5 = 1
%sp = 5e4c1f0 %o7 = 5c4fed4
05c4fee4 d2022030 ld [%o0 + 0x00000030], %o1
05c4fee8 91326005 srl %o1, 5, %o0
05c4feec 93322000 srl %o0, 0, %o1
05c4fef0 a0100009 mov %o1, %l0
05c4fef4 92100010 mov %l0, %o1
05c4fef8 912a6002 sll %o1, 2, %o0
05c4fefc 9207bf70 add %fp, 0xffffff70, %o1
05c4ff00 96100010 mov %l0, %o3
05c4ff04 952ae002 sll %o3, 2, %o2
05c4ff08 9607bf70 add %fp, 0xffffff70, %o3
05c4ff0c 1b01c4c5 sethi %hi (snmp_sck), %o5
05c4ff10 98136020 or %o5, %lo (snmp_sck), %o4
05c4ff14 da032030 ld [%o4 + 0x00000030], %o5
05c4ff18 980b601f and %o5, 0x1f, %o4
05c4ff1c 9a102001 mov 1, %o5
05c4ff20 992b400c sll %o5, %o4, %o4
05c4ff24 d402c00a ld [%o3 + %o2], %o2
05c4ff28 9612800c or %o2, %o4, %o3
05c4ff2c d6224008 st %o3, [%o1 + %o0]
05c4ff30 1301c4c5 sethi %hi (snmp_sck), %o1
05c4ff34 90126020 or %o1, %lo (snmp_sck), %o0
05c4ff38 d2022030 ld [%o0 + 0x00000030], %o1
05c4ff3c 90026001 add %o1, 1, %o0
05c4ff40 933a2000 sra %o0, 0, %o1
05c4ff44 9407bf70 add %fp, 0xffffff70, %o2
ion
WED APR 07 09:25:54 : TELNET (80) error message:
+++ Cannot create IP socket, cmmTelnetLib.c, cmmtelnetd, 2961
WED APR 07 09:25:54 : SYSTEM (75) error message:
+++ Exception: Data Access Exception
+++ program counter: 0x05c4ff24
pstate: 0x0000001e
+++ next program counter: 0x05c4ff28
+++ pstate: 0x0000001e
Task: 0x5e4+++ c4b011 "a4c0SNMP GTWfsr: "
vxTaskEntry +c : snmp_udp_gtw (0, 0, 0, 0, 0 0x000000030f400, 8200)
5c4fed4 snmp_udp_gtw +94 : bzero
(1ffffffc, 5e4c340, 1ffffffc, 5e4c340, 80000000, 1)
18291c excEnter +100: 0 (30, 5e4c000, 0, 5e4c3c0, 5e4c3c0, f3ac0)
11192c excExcHandle +14c: csCsmAppliStrSend (5e4c4b0, 30, 5e4c000, &csCsmAppliStrSend, d73a0, 989680)
676ec6c csCsmAppliStrSend+16c: csCsmSendMsg (1, 1, 699771c, 5f63210, b0, 5e4bca0)
6789540 csCsmSendMsg +40 : zcSendto (1, 699771c, 5f63210, b0, 5e4bca0, 4)
71c2930 zcSendto +5b0: IpctaskUnlock (0, 18, 17, 4, ffffffff, 0)
71bf750 IpctaskUnlock +10 : semGive (6993658, &IpcGlobalSem, a, 2, 0, 32c400)
170f08 semGive +68 : semMGive (f, &semGiveTbl, 4, &semMGive, &semMTake, 3a)
17212c semMGive +20c: semMGiveKern (6993658, 243800, 1, 0, 0, 1)
WED APR 07 09:25:58 : CSM-CHASSIS (103) info message:
+++ CS excep handler: exception 48 in task 0x5e4c4b0
WED APR 07 09:25:58 : SYSTEM (75) error message:
+++ access address: 0x25e4c33c
+++ Task: 0x5e4c4b0 "SNMP GTW"
WED APR 07 09:25:59 : CSM-CHASSIS (103) alarm message:
+++ **************** STR ****************
+++ Level : ERROR DETECTED - APPLICATION FATAL
+++ Not an application managed by Chassis Supervision
+++ taskId : 0X05E4C4B0
+++ Source file name : ??????
+++ Line number in the file : 0
+++ Error number : 0X00000030
+++ Comments : exception in task 0x5e4c4b0
+++ Data Size : 00000040
+++ Data Address : 06D180A0
+++ 0x05F63280 0000 0000 0000 0000 0000 0000 0000 0000 ................
+++ 0x05F63290 0000 0000 0000 0000 0000 0000 0000 0000 ................
+++ 0x05F632A0 0000 0000 0000 0000 0000 0000 0000 0000 ................
+++ 0x05F632B0 0000 0000 0000 0000
pstate: 0x0000001e
pstate: 0x0000001e
WED APR 07 09:25:59 : CSM-CHASSIS (103) info message:
+++ !!!REBOOT!!!
WED APR 07 09:26:00 : CSM-CHASSIS (103) info message:
+++ !!! REBOOT WITH PMD !!!
+++ Application & Watchdog Monitoring Stopped
+++ !!!System will be reboot after the PMD dump. Please wait!!!
WED APR 07 09:26:05 : CSM-CHASSIS (103) info message:
+++ !!!PMD dump done. System is rebooting now!!!
7800
rajashokkumar
Re: 7800
Post by rajashokkumar »
I believe somehow you files in the flash might be corrupted/deleted.
Check whether this post is helping..
viewtopic.php?f=189&t=14688&p=63036&hil ... ery#p63036
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
