Migration OTBE R1.2.000.055 to R2.1.000.093
cheo
Post by cheo »
Hi all,
I'm confused with a migration on OTBE R1.2.000.055 to R2.1.000.093 (the new one). When I read the release note I understand that I need to migrate to 1.3 and then I can't migrate on active/inactive partition to 2.1, it's correct? I have to install 2.1 on new server?
Thanks.
ltatge
Post by ltatge »
There is TechComm 2046. Here are discribed the steps for upgrade older versions.
Didn't read in detail, but I think it's new installation and restore old backup.
Regards LT
cheo
Re: Migration OTBE R1.2.000.055 to R2.1.000.093
Post by cheo »
Thank you a lot !!!
This TC is about 2.0, do you know the same for 2.1 ?
It's describe to install from scratch so I need a new server ?
ltatge
Post by ltatge »
Check release notes for R2.1, there are Hardware-Requirements. Or in Installation Manual.
Regards LT
Return to “OTBE - OpenTouch Business Edition”
