Hi all,
I used Voice Mail 4645 for my Auto Attendant system. I can change greeting audio by record new one via IP Touch set (4018). The question is, is there any way to upload my own audio file to Auto Attendant system?
I'm using OXE R11.
Thank you all
Upload audio file for Auto Attendant
Re: Upload audio file for Auto Attendant
hi, for 4645 you can upload messages with Evatool command.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
soilun
Sorry for my dumb question, but can you tell more details about this process? I only know using Eva_tool to manage mail box.murraya wrote:hi, for 4645 you can upload messages with Evatool command.
its all in the doc's. check out the 4645 maintenance section. interactive import of greeting.
Alcatel-Lucent 4645 VMS
Maintenance
Table of contents
General
vmail
The Eva-tool command
Activation
Option 1: Delete a mailbox
Option 2: Modify a password
Option 3: Delete all messages from mailbox
Option 4: Delete messages
Option 5: Dump nodes, mailboxes and messages
Option 6: Reset a port
Option 7: Update led
Option 8: Status of line
Option 9: Disable lines after hanging up
Option 10: Force disable all line
Option 11: Enable all lines
Option 12: Interactif import of greeting
Option 13: Automatic import of greetings
Option 15 : Un-lock a mailbox
Option 16 : Un-lock all mailboxes
Maintenance
Table of contents
General
vmail
Activation
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
