How to change MTU on 6250
hanszie01
Post by hanszie01 »
I can not change the mtu value on a 6250 Switch
The intention is to bring the MTU value of default 1,500 to 1,400
Can not find the right commands ?
thx
Re: How to change MTU on 6250
You can only change the mtu in OS6860. Not in 6250/6450 and not in 6850E. You can change the frame size (L2 instead of L3 like with mtu).
Not sure about the command. Try something like this > Interface 1/1 frame ?...
Return to “OmniSwitch 6250”
