Service sap ingress /egress data throughput monitoring
aman
Post by aman »
Hi All,
Can anyone share some thoughts if Services sap ingress /egress data throughput monitoring is possible on 7750, 7705 and 7210 ALU products ?
If it is then what it is? Would "collect-states" be enough under sap ingress and egress to allow us the ingress /egress throughput monitoring on per service base?
Any thoughts would be greatly appreciated.
Aman
mivens
Re: Service sap ingress /egress data throughput monitoring
Post by mivens »
Take a look at the TIMETRA-SAP-MIB.
You can SNMP poll objects in the sapBaseStatsTable for ingress and egress forwarded packets.
rekeds
Post by rekeds »
yep, we do sap monitoring from 7xxx series
evans
Post by evans »
Hallo,
kindly assist me the procedure of how to do this [ sap monitoring] via cacti i.e. Take a look at the TIMETRA-SAP-MIB. [ as you had indicated in your earlier post]
Evans kipkemoi
mivens
Post by mivens »
Here are some SNMP objects from the TIMETRA-SAP-MIB you could poll using Cacti for SAP ingress/egress stats. You'd need to create the XML configuration to add these to Cacti.
sapBaseStatsIngressQchipForwardedInProfOctets (.1.3.6.1.4.1.6527.3.1.2.4.3.6.1.12)
sapBaseStatsIngressQchipForwardedOutProfOctets (.1.3.6.1.4.1.6527.3.1.2.4.3.6.1.14)
sapBaseStatsEgressQchipForwardedInProfOctets (.1.3.6.1.4.1.6527.3.1.2.4.3.6.1.20)
sapBaseStatsEgressQchipForwardedOutProfOctets (.1.3.6.1.4.1.6527.3.1.2.4.3.6.1.22)
Ahmed Dema
Post by Ahmed Dema »
you can use PRTG application, just add the MIB's of 7705 in the MIBs of PRTG and then enable snmp with credential information on both side, then the PRTG can create a sensor depending on the port or SAP and read the ingress/egress also you can monitor the subnet it self,
Ahmed Dema
kibwana
Post by kibwana »
Hi. Anyone with a working 7XXX SAP graphing template for cacti? That would be of immense help to me. Thanks.
sayrus
Post by sayrus »
I do via zabbix, but I do not have a template that will serve you since changing the position of the plates changes everything ... but you can use The Dude to get the OIDs with his snmpwalk
shadowmaker
Post by shadowmaker »
kibwana wrote: 21 Mar 2017 09:48 Hi. Anyone with a working 7XXX SAP graphing template for cacti? That would be of immense help to me. Thanks.
Hi everyone, I am looking for the same than Kibwana is.
If You can help me I will be gratefull.
Thanks in advance for any response.
Best Regards
Oums
Post by Oums »
Hi all ,
Anynone working with sap for cacti (7750 and 7705 SAR-8) , many thanks for you help
thanks in advance
Return to “7750 SR”
