4635 - Impossible to install release 5.6
jpissot
Post by jpissot »
I try to install R5.6 on VPU5 with new HDD.
The installation seems to be correct, the VPU5 load file with bootpd.
But when the VPU5 reboot, the boot stops at VPx35 login whereas I am not connect on modem port, I don't see the Boot Command Menu.
Thank you for your help.
Upgrade Firmware [Y/n] y
BIOS Upgrade:
Installed BIOS Version: VPU5 4.10
Available BIOS Version: VPU5 4.10
Upgrade BIOS: [N/y] y
Loading Hex File... 212362 Bytes Loaded
Read Flash-EPROM ID...
Erase Flash-EPROM...
Program Flash-EPROM...
Verify Flash...
DIAG Upgrade:
Installed DIAG Version: VPU5 108
Available DIAG Version: VPU5 108
Upgrade DIAG: [N/y] y
Loading Hex File... 139830 Bytes Loaded
Verify Flash...
A4635 System Selection: (Release 5.6.0.)
1) H2 2) J 3) V
System type (1-3) : [V] 3
Installation Type Selection:
U) Upgrade I) Installation L) add Languages E) Experts ONLY
Installation Type: [U/i/l/eu/ei] i
You selected an action which may cause loss of data!
Please enter Access Code: a4635
Drive definition:
Drv#0: V Drv#1: NO Drv#2: NO Drv#3: NO Drv#4: NO
Drive partitioning:
Partitioning Drive /dev/hda as "V" selected.
LINUX System Installation on Drive 0 selected.
A4635 Installation of Drive 0 as Type V: please wait..
Current Languages selected:
#0= #1= #2= #3=
#4= #5= #6= #7=
1) Americ.English 2) Arabic........ 3) Austr.English. 4) Brit.English..
5) Brazil.Portug. 6) Catalan....... 7) Czech......... 8) Danish........
9) Dutch......... 10) Europ.French.. 11) Europ.Spanish. 12) Finnish.......
13) Flemish....... 14) German........ 15) HonkongCanton. 16) Croatian......
17) Hungarian..... 18) Italian....... 19) Lithuanian.... 20) Mandarin......
21) Norwegian..... 22) Polish........ 23) Europ.Portug.. 24) Romanian......
25) Russian....... 26) Swedish....... 27) Slovak........ 28) Slovenian.....
29) Americ.Spanish 30) Turkish.......
Install language #0: 10
Install language #1: 4
Install language #2:
#0= Europ.French.. #1= Brit.English.. #2= #3=
#4= #5= #6= #7=
Accept current settings [Y/n] y
Current USERS and CDRS settings:
USERS=15000 CDRS=5000
Activate A4635 Installation on Drive 0 (/dev/hda2) [Y/n] y
A4635 Installation of Drive 0 as Type V selected.
Install [Y/n] y
A4635 Format Drive Version 4.1
Detecting drive geometry on Drive /dev/hda..
Drive /dev/hda: cylinder 4864, heads 255, sectors 63, blocks 78140160
Stopping RAID1 on /dev/md0
Stopping RAID1 on /dev/md1
Stopping RAID1 on /dev/md2
Stopping RAID1 on /dev/md3
Stopping RAID1 on /dev/md4
Cleaning partition table..
Drive /dev/hda: formatting limited to cylinder 1826, heads 255, sectors 63, blocks 29334690
Preparing partition 1 type 85 (1218 Cyls.)..
Preparing partition 2 type a8 (608 Cyls.)..
Preparing partition 5 type fd (133 Cyls.)..
Preparing partition 6 type fd (133 Cyls.)..
Preparing partition 7 type fd (126 Cyls.)..
Preparing partition 8 type 82 (122 Cyls.)..
Preparing partition 9 type fd (293 Cyls.)..
Preparing partition 10 type fd (411 Cyls.)..
Creating all prepared partitions ...
Partitioning drive /dev/hda finished.
A4635 Prepare Linux System Version 4.4
Formatting /dev/md2 (data)
Creating swap partition on /dev/hda8
Formatting /dev/md3 (log)
Formatting /dev/md4 (spool)
Formatting /dev/md0
Linux pre_install /dev/md0
Creating Linux System ...
Loading System file.. Installing Linux..
Setting up bootloader..
Linux post_install /dev/md0
Formatting /dev/md1
Linux pre_install /dev/md1
Bootloader not installed on Drive /dev/md1
Linux post_install /dev/md1
Loading software:...........:init:.....
Loading lang ef as #0
Loading lang be as #1
The Installation is correctly made.
Do You want to exit [Y/n] y
Bye.
INIT: Entering runlevel: 2
4635 Installation and Maintenance
To Install System: login as `swinst'
To Reboot System: login as `reboot'
192.254.1.2 login: reboot
INIT:
Syncing disks...
Unmounting file systems...
Stand by while rebooting the system...
Restarting system.
ALCATEL - VPU5 - BIOS
Version: 4.10 Date: Dec 22, 2006 10:21:05
(C) Copyright Alcatel Illkirch S.A. 2006
CPU Type is SC520 Rev 11 running at 100 MHz
<SPACE> to Skip Memory Test, <DEL> for BIOS Setup
LILO boot:
Loading linux........
Uncompressing Linux... Ok, booting the kernel.
Linux version 2.2.19 (vobadm35@lenz) (gcc version 2.95.2 19991024 (release)) #2 Mon Feb 23 14:59:25 CET 2004
BIOS-provided physical RAM map:
BIOS-e820: 0009f000 @ 00000000 (usable)
BIOS-e820: 03f00000 @ 00100000 (usable)
Calibrating delay loop... 49.56 BogoMIPS
Memory: 63352k/65536k available (824k kernel code, 416k reserved, 892k data, 52k init)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Dentry hash table entries: 8192 (order 4, 64k)
Buffer cache hash table entries: 65536 (order 6, 256k)
Page cache hash table entries: 16384 (order 4, 64k)
CPU: AMD 486 DX/4-WB stepping 04
Checking 386/387 coupling... OK, FPU using exception 16 error reporting.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
PCI: Using configuration type 1
PCI: Probing PCI hardware
Linux NET4.0 for Linux 2.2
Based upon Swansea University Computer Society NET3.039
NET4: Unix domain sockets 1.0 for Linux NET4.0.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 65536 bhash 65536)
Starting kswapd v 1.5
Serial driver version 4.27 with A4635_STDL enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
pty: 256 Unix98 ptys configured
Crystal-1 NV Driver, (C) Copyright Alcatel Austria 2001, Ver 0.97 running in STDL mode
C1NV: chip mode=2 version=2
RAM disk driver initialized: 16 RAM disks of 6144K size
PCI_IDE: unknown IDE controller on PCI bus 00 device 28, VID=3500, DID=1100
PCI_IDE: device not capable of full native PCI mode
PCI_IDE: device disabled (BIOS)
hda: Hitachi HEN421040G9AT00, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: Hitachi HEN421040G9AT00, 38154MB w/7509kB Cache, CHS=4864/255/63
md driver 0.90.0 MAX_MD_DEVS=256, MAX_REAL=12
raid1 personality registered
eth0: NatSemi DP83815 at 0xe800, 00:80:9f:53:90:80, IRQ 9.
eth0: Transceiver status 0x786d advertising c5e1.
natsemi.c:v1.11 11/7/2001 Written by Donald Becker <becker@scyld.com>
http://www.scyld.com/network/natsemi.html
md.c: sizeof(mdp_super_t) = 4096
Partition check:
hda: hda1 < hda5 hda6 hda7 hda8 hda9 hda10 > hda2
autodetecting RAID arrays
(read) hda5's sb offset: 1068160 [events: 00000002]
(read) hda6's sb offset: 1068224 [events: 00000002]
(read) hda7's sb offset: 1011968 [events: 00000002]
(read) hda9's sb offset: 2353408 [events: 00000002]
(read) hda10's sb offset: 3301248 [events: 00000002]
autorun ...
considering hda5 ...
adding hda5 ...
created md0
bind<hda5,1>
running: <hda5>
now!
hda5's event counter: 00000002
md0: max total readahead window set to 128k
md0: 1 data-disks, max readahead per data-disk: 128k
raid1: device hda5 operational as mirror 0
raid1: md0, not all disks are operational -- trying to recover array
raid1: raid set md0 active with 1 out of 3 mirrors
md: updating md0 RAID superblock on device
hda5 [events: 00000003](write) hda5's sb offset: 1068160
md: recovery thread got woken up ...
md0: no spare disk to reconstruct array! -- continuing in degraded mode
md: recovery thread finished ...
considering hda6 ...
adding hda6 ...
created md1
bind<hda6,1>
running: <hda6>
now!
hda6's event counter: 00000002
md1: max total readahead window set to 128k
md1: 1 data-disks, max readahead per data-disk: 128k
raid1: device hda6 operational as mirror 0
raid1: md1, not all disks are operational -- trying to recover array
raid1: raid set md1 active with 1 out of 3 mirrors
md: updating md1 RAID superblock on device
hda6 [events: 00000003](write) hda6's sb offset: 1068224
md1: no spare disk to reconstruct array! -- continuing in degraded mode
considering hda7 ...
adding hda7 ...
created md2
bind<hda7,1>
running: <hda7>
now!
hda7's event counter: 00000002
md2: max total readahead window set to 128k
md2: 1 data-disks, max readahead per data-disk: 128k
raid1: device hda7 operational as mirror 0
raid1: md2, not all disks are operational -- trying to recover array
raid1: raid set md2 active with 1 out of 3 mirrors
md: updating md2 RAID superblock on device
hda7 [events: 00000003](write) hda7's sb offset: 1011968
md2: no spare disk to reconstruct array! -- continuing in degraded mode
considering hda9 ...
adding hda9 ...
created md3
bind<hda9,1>
running: <hda9>
now!
hda9's event counter: 00000002
md3: max total readahead window set to 128k
md3: 1 data-disks, max readahead per data-disk: 128k
raid1: device hda9 operational as mirror 0
raid1: md3, not all disks are operational -- trying to recover array
raid1: raid set md3 active with 1 out of 3 mirrors
md: updating md3 RAID superblock on device
hda9 [events: 00000003](write) hda9's sb offset: 2353408
md3: no spare disk to reconstruct array! -- continuing in degraded mode
considering hda10 ...
adding hda10 ...
created md4
bind<hda10,1>
running: <hda10>
now!
hda10's event counter: 00000002
md4: max total readahead window set to 128k
md4: 1 data-disks, max readahead per data-disk: 128k
raid1: device hda10 operational as mirror 0
raid1: md4, not all disks are operational -- trying to recover array
raid1: raid set md4 active with 1 out of 3 mirrors
md: updating md4 RAID superblock on device
hda10 [events: 00000003](write) hda10's sb offset: 3301248
md4: no spare disk to reconstruct array! -- continuing in degraded mode
... autorun DONE.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 52k freed
INIT: version 2.78 booting
Running /sbin/init.d/boot
Mounting /proc device
Activating swap-device /dev/hda8
Adding Swap: 130748k swap-space (priority -1)
Checking file systems...
Parallelizing fsck version 1.18a (11-Nov-1999)
/dev/md0: clean, 1005/133632 files, 11079/267040 blocks
/dev/md1: clean, 1003/133632 files, 11076/267056 blocks
/dev/md2: clean, 36/126720 files, 4015/252992 blocks
/dev/md3: clean, 15/294336 files, 9251/588352 blocks
/dev/md4: clean, 27/412672 files, 12983/825312 blocks
Mounting local file systems...
proc on /proc type proc (rw)
/dev/md2 on /data type ext2 (rw)
/dev/md3 on /data/var/log type ext2 (rw)
/dev/md4 on /data/var/spool type ext2 (rw)
none on /dev/pts type devpts (rw)
Starting ldconfig (setting up /etc/ld.so.cache)
Setting up loopback device
Setting up hostname
Running /sbin/init.d/boot.local
Freeing Ramdisk
Creating /var/log/boot.msg
Disabling IP forwarding
INIT: Entering runlevel: 1
Master Resource Control: previous runlevel: N, switching to runlevel: 1
Starting syslog services
INIT: Switching to runlevel: 2
Master Resource Control: runlevel 1 has been reached
INIT: Sending processes the TERM signal
Master Resource Control: previous runlevel: 1, switching to runlevel: 2
Starting service dhcp client on eth0
Starting INET services (inetd)
Starting CRON daemon
Master Resource Control: runlevel 2 has been reached
crysd V.01.01
A4635 Application Server
VPx35 login:
tgn
Re: 4635 - Impossible to install release 5.6
Post by tgn »
maybe connected to the wrong serial port?
one port is for linux terminal
the other port is for the application menu.
regards...
jpissot
Post by jpissot »
I use the black cable but I have also VPX35 login on the red cable (modem cable).
Before the loading, I used black cable to access to MEVO MENU.
jpissot
Post by jpissot »
I ve found. The Vps35 booted from disk instead of EEPROM.
Return to “Voicemail (46x5)”
