INTIP3/GD3/GA3 SD of death
Krusty65
Post by Krusty65 »
So,
You get a brand new shiny INTIP3, GD3 or GA3 card and it you hurry to a system to install some firmware on it and get it working.....
But when you fire up that wonderful bit of SW PC Installer and get all of the bits connected the upload fails at the end of the third file with a "Verifying Checksum ... Bad Data CRC" message :(
Don't despair, don't raise a e-SR (as you will spend three days trying to explain to the muppet at the other end of the internet that YOU ARE DOING THE INSTRUCTIONS FROM TC0521 AND THEY DON'T WORK (oops sorry for shouting)
What you do is the following.
Get the files off a working card and copy them onto the SD card of death from the board using a linux distro or ext2fsd (program that lets you read and write ext file system on windows) and stick it back in the board.
Boot the board and if necessary tell the board to boot from SD, allow it to boot up and then set PC Installer going with the correct options for your board as per TC0521
Reboot the board and get it to boot from Ethernet, this should now work ok.
Put shiny new board into the OxE and play away.
K.
Re: INTIP3/GD3/GA3 SD of death
Hahaha laughed so much with the puppet one... Did you plugged the board? Lol
Enviado de meu C6602 usando Tapatalk
tgn
Post by tgn »
^^ this is just... "the same procedure than every day" ^^
swinstu
Post by swinstu »
Can someone please share the contents of working INTIP 3 working SD card as I have a dud I need to sort ASAP.
OXE release will be R11.1 L130128b.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Return to “Boards”
