Sip trunk in server 8450/OXE
gilmar
Post by gilmar »
hello guys , my server 8450 no fax tone when I call him an analog extension , and therefore can not receive nehum document , does anyone know what the problem ?, I'm a single bond, only the server and the PABX in a single switc
thanks
Re: Sip trunk in server 8450/OXE
Check codecs. G711. 8450 must be declared on IP Domain so you make it G711 only.
Enviado de meu C6602 usando Tapatalk
cav i have run ofs and oxe with g729 with no probelm
For fax? Voice trunk can be but fax?
fax wth g729 as codec
R9.1
OK I Can't upload the logfile
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.08.06 11:59:24 =~=~=~=~=~=~=~=~=~=~=~=
Alcatel-Lucent OmniPCX Enterprise
pst_cpu6 login: mtcl
Password:
Last login: Thu Aug 6 11:53:22 on ttyS1
standard installation last performed: 04-Jun-2012 13:42:43
# The role of the CPU is MAIN
Application software identity
R9.1-i1.605-38-
Business identification: R9.1
Release:
DELIVERY i1.605
Patch identification: 38
Dynamic patch identification: none
Country:
Cpu: c7s2
ACD VERSION
release : 8
bug_fixing : 1
protocol_id : 90
version_dy_hr_stat : 11
(1)pst_cpu6> exittimout motortrace 3
motortrace (v5.2.0) verbosity = 0037b524
sipmotor trace-level set 3 (All traces).
(1)pst_cpu6> traced
** UNIX-trace-daemon started ... (static user group No 1) **
traced started ...
1438858823 -> EAu: Block Memory Size: 82900
1438858823 -> EAu: Dupli window: 0/1 (max: 0)
1438858826 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858826 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858826 -> [exec_ipc] in 1744.
1438858826 -> [display_ipc_in] ------------ Begin ---------------
1438858826 -> neqt : 3292 Id : -1
1438858826 -> INVITE
1438858826 -> REQUEST URI : <> 38982000@10.235.96.150:5061 ; user=phone
1438858826 -> FROM : <> 505886@10.235.96.130:5060 ; user=phone
1438858826 -> TO : <> 38982000@10.235.96.150:5061 ; user=phone
1438858826 -> CAC : 0
1438858826 -> neqt CAC : -1
1438858826 -> CLIR : 0
1438858826 -> SDP :
1438858826 -> ADDRESS : 10.235.96.147 :32124
1438858826 -> ALGOS :
1438858826 -> G729
1438858826 -> G723
1438858826 -> PCMA
1438858826 -> 97
1438858826 -> DIRECTION : SEND & RECEIVE
1438858826 -> N_GW_EXT : 1
1438858826 -> [display_ipc_in] ------------- End ----------------
1438858826 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 3292--1.
1438858826 -> [CMotorCallManager::onIncomingEvent] New Call created.
1438858826 -> [CMotorCallManager::callFactory].
1438858826 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R9.1 i1.605.38
1438858826 -> [CMotorCallManager::callFactory]=ce721e8.
1438858826 -> [CMotorCallManager::onIncomingEvent] eqt=3292 -1.
1438858826 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 3292 inserted.
1438858826 -> [quoteString] => ""
1438858826 -> 1130[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
1438858826 -> 1130[CMotorCall::setFilterUsedMode] To be traced = 0
1438858826 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1438858826 -> [onIncomingEvent] INVITE arrived.
1438858826 -> [receiveInviteEvent] Call: eqt: 3292 INITIAL_STATE received an event.
1438858826 -> 1130[CMotorCall::emitInviteMessage] begin.
1438858826 -> [isValidGwExt] ext gw 1 is valid
1438858826 -> 1130[CMotorCall::inviteBuildAurlWithBelongingDomain] extGw=1
1438858826 -> [is_addr_in_dico] user=38982000 host=10.235.96.150
1438858826 -> [isUserDeclared] 38982000@10.235.96.150
1438858826 -> [isUserDeclared] found in the dictionnary.
1438858826 -> [is_addr_in_dico] other sip user
1438858826 -> 1130[CMotorCall::inviteBuildAurlWithoutBelongingDomain] P-Asserted-Identity: "" <sip:505886@10.235.96.130;user=phone>
1438858826 -> 1130[CMotorCall::emitInviteMessage] From: "" <sip:505886@10.235.96.130;user=phone>
1438858826 -> 1130[CMotorCall::emitInviteMessage] reqUri :sip:38982000@10.235.96.150:5061;user=phone
1438858826 -> 1130[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1
1438858826 -> 1130[CMotorCall ABCF ExtGW
1438858826 -> 1130[CMotorCall::inviteBuildSupportedHeader] Invite directed to external gw : 1
1438858826 -> 1130[CMotorCall::emitInviteMessage] Request Uri : sip:38982000@10.235.96.150:5061;user=phone
1438858826 -> 1130[CMotorCall::emitInviteMessage] To: <sip:38982000@10.235.96.150:5061;user=phone>
1438858826 -> am_I_PCS SCSWorking : NO
1438858826 -> check_PCSstate
1438858826 -> check_PCSstate stat of PCS is : -1
1438858826 -> 1130[CMotorCall::inviteBuildContact] begin. crms00137339
1438858826 -> [137339 - inviteBuildContact] trunk_number=1799 extGw =1.
1438858826 -> [137339-InviteBuildContact] userinfo : 505886
1438858826 -> 1130[CMotorCall::inviteBuildContact] Contact: sip:505886@10.235.96.130
1438858826 -> 1130[CMotorCall::emitInviteMessage] uacGatewayMode=1 uacRefresher=1.
1438858826 -> 1130[CMotorCall::makeRequestSdp] Begin sdp.
1438858826 -> 1130[CMotorCall::makeRequestSdp] Direction: 0.
1438858826 -> 1130[CMotorCall::makeRequestSdp] format 97
1438858826 -> 1130[CMotorCall::makeRequestSdp] Final sdp.
1438858826 -> 1130[CMotorCall::emitInviteMessage] The sdp build.
1438858826 -> 1130[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] isResolution=0.
1438858830 -> [isValidGwExt] ext gw 1 is valid
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] target is not the local node.
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 38982000
1438858830 -> [isUserDeclared] 38982000@10.235.96.150
1438858830 -> [isUserDeclared] found in the dictionnary.
1438858830 -> [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest]-->extGw=1
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] contact : sip:38982000@10.235.96.150:5061;user=phone
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] nb available licenses=14 .
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=10.235.96.150
1438858830 -> 1130[CMotorCall::makeInitialMotorRequest] user= 38982000
1438858830 -> [CGWMngData::isMainServer] CPU is MAIN.
1438858830 -> [CGWMngData::isMainServer] checkwith PCS = 0
1438858830 -> [CMotorCall::makeInitialMotorRequest] count = 3.
1438858830 -> [CMotorCall::makeInitialMotorRequest] service=0 0xbffff0b8.
1438858830 -> [CMotorCall::makeInitialMotorRequest] service=1 0xbfffed58.
1438858830 -> [CMotorCall::makeInitialMotorRequest] service=2 0xbfffe73c.
1438858830 -> 1130 [CCall::makeGenericRequest] INVITE
1438858830 -> 1130 [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
1438858830 -> 1130 [CCall::getDialog] Initial Dialog Client not found
1438858830 -> 1573 [CDialog::createRequest]
1438858830 -> 1573 [CDialog::buildServicesForAllRequest]
1438858830 -> 1573 [CDialog::createInviteRequest]
1438858830 -> 21b2 [CTransaction::changeState] STATE CHANGED TO INITIAL
1438858830 -> 21b2 [CTransaction::changeState] notifying the parent dialog
1438858830 -> 1573 [CDialog::onTransactionState(pTrans = 21b2, previousState = Terminated, currentState = Initial, reason = None]
1438858830 -> 2FE7 [CRequest::CRequest] Creation of a request
1438858830 -> 2FE7 [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858830 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 1132)
INVITE sip:38982000@10.235.96.150:5061;user=phone SIP/2.0Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFOSupported: replaces,timer,100relUser-Agent: OmniPCX Enterprise R9.1 i1.605.38Session-Expires: 1800;refresher=uacMin-SE: 900P-Asserted-Identity: "" <sip:505886@10.235.96.130;user=phone>Content-Type: application/sdpTo: <sip:38982000@10.235.96.150:5061;user=phone>From: "" <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54Contact: <sip:505886@10.235.96.130;transport=UDP>Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640799 INVITEVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bKce535808c0f555491d6099c46f253abfMax-Forwards: 70Content-Length: 341v=0o=OXE 1438858826 1438858826 IN IP4 10.235.96.130s=absc=IN IP4 10.235.96.147t=0 0m=audio 32124 RTP/AVP 18 4 8 97a=sendrecva=rtpmap:18 G729/8000a=fmtp:18 annexb=noa=ptime:20a=maxptime:40a=rtpmap:4 G723/8000a=ptime:30a=maxptime:30a=rtpmap:8 PCMA/8000a=ptime:20a=maxptime:30a=rtpmap:97 telephone-event/8000-------------------------------------------------
1438858830 -> 21b2 [CTransInitialState::createRequest] Transaction changes to Calling state
1438858830 -> 21b2 [CTransaction::changeState] STATE CHANGED TO CALLING
1438858834 -> 21b2 [CTransaction::changeState] notifying the parent dialog
1438858834 -> 1573 [CDialog::onTransactionState(pTrans = 21b2, previousState = Initial, currentState = Calling, reason = Request creation]
1438858834 -> 21b2 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
1438858834 -> 21b2 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
1438858834 -> 1573 [CDialog::getTransactionByCSeq] CSeq = 1033640799
1438858834 -> 1573 [CDialog::addTransaction] added transaction 21b2 with branch z9hG4bKce535808c0f555491d6099c46f253abf, with CSeq 1033640799
1438858834 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
1438858834 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1438858834 -> [CSessionTimerContext::updateSupported] Request timer supported
1438858834 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1438858834 -> [CSessionTimerContext::updateSessionExpires] header value : 1800
1438858834 -> [CSessionTimerContext::updateSessionExpires] updated
1438858834 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1438858834 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1438858834 -> 1130[CMotorCall::makeInitialMotorRequest] nb contact=1.
1438858834 -> [CForkedBranch::CForkedBranch] context = 0xce72650.
1438858834 -> 1130[CMotorCall::branchAllocation] built branch number=1.
1438858834 -> 1130[CMotorCall::branchAllocation] pForkedBranch = 0xce77740.
1438858834 -> 1130[CMotorCall::makeInitialMotorRequest] reqUri duplication pForkedBranch = 0xce77740.
1438858834 -> 1130[CMotorCall::makeInitialMotorRequest] reqUri duplication2.
1438858834 -> 1130[CMotorCall::getOutgoingCall] outgoingCall:1
1438858834 -> 1130 [CCall::getCallDuplicationData]
1438858834 -> [CViaSetSerializer::copy] Added via 7cb3 at index 0
1438858834 -> 1130 [CCall::getCallDuplicationData] : Request URI = sip:38982000@10.235.96.150:5061;user=phone, Call ID = 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130, Local URI = sip:505886@10.235.96.130;user=phone, Local Tag = 30592e426cd4efc607af604150e3ba54, Remote URI = sip:38982000@10.235.96.150:5061;user=phone, Remote Tag = , Local CSeq = 1033640799, Remote CSeq = 0
1438858834 -> [CViaSetSerializer::serialize] Serialized via set : ViaSerialize=Via: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bKce535808c0f555491d6099c46f253abf
1438858834 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858834 -> [onIncomingEvent] CallID must be inserted.
1438858834 -> [onIncomingEvent] CallID inserted.
1438858834 -> [exec_ipc] in end 1744.
1438858834 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
SIP/2.0 100 TryingVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bKce535808c0f555491d6099c46f253abfFrom: "" <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54To: <sip:38982000@10.235.96.150:5061;user=phone>Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640799 INVITEAllow: INVITE, ACK, BYE, CANCELContact: <sip:38982000@10.235.96.150:5061;user=phone>Server: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Length: 0-------------------------------------------------
1438858834 -> [CIOCom::receiveResponse] CResponse 2C9A ref=1
1438858834 -> [CDispatcher::onIncomingResponse]
1438858834 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1438858834 -> 102 [CCallManager::onIncomingResponse]
1438858834 -> 1130 [CCall::receiveResponse] 100
1438858834 -> 1130 [CCall::receiveResponse]Trying to find the right dialog
1438858834 -> 1130 [CCall::getDialog] Confirmed Dialog is not found (ID = 30592e426cd4efc607af604150e3ba54;)
1438858838 -> 1130 [CCall::getDialog] Returning Initial Dialog Client
1438858838 -> 1130 [CCall::receiveResponse]One dialog found
1438858838 -> 1573 [CDialog::receiveResponse]
1438858838 -> 21b2 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
1438858838 -> 21b2 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1438858838 -> 21b2 [CTransaction::changeState] notifying the parent dialog
1438858838 -> 1573 [CDialog::onTransactionState(pTrans = 21b2, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
1438858838 -> 21b2 [CTransaction::freeTimerToken] Timer A is freed
1438858838 -> 21b2 [CTransaction::freeTimerToken] Timer B is freed
1438858838 -> 1130[CMotorCall::searchForkedBranch]pForkedBranch=0xce77740.
1438858838 -> [receiveInformationalMessage] Call: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 eqt: 3292 PROCEEDING_STATE received a message.
1438858838 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
SIP/2.0 200 OKVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bKce535808c0f555491d6099c46f253abfFrom: "" <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=783B5BD69270Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640799 INVITEAllow: INVITE, ACK, BYE, CANCELContact: <sip:38982000@10.235.96.150:5061;user=phone>Server: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Type: application/sdpContent-Length: 186v=0o=XMedius-Fax-Gateway 39514127 127 IN IP4 10.235.96.150s=absc=IN IP4 10.235.96.150t=0 0m=audio 54596 RTP/AVP 18 101a=sendrecva=rtpmap:18 G729/8000a=fmtp:18 annexb=no-------------------------------------------------
1438858838 -> [CIOCom::receiveResponse] CResponse 2C9B ref=1
1438858838 -> [CDispatcher::onIncomingResponse]
1438858838 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1438858838 -> 102 [CCallManager::onIncomingResponse]
1438858838 -> 1130 [CCall::receiveResponse] 200
1438858838 -> 1130 [CCall::receiveResponse]Trying to find the right dialog
1438858838 -> 1130 [CCall::getDialog] Confirmed Dialog is not found (ID = 30592e426cd4efc607af604150e3ba54;783B5BD69270)
1438858838 -> 1573 [CDialog::receiveResponse] create a CONFIRMED dialog
1438858838 -> 1574 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bKce535808c0f555491d6099c46f253abf
1438858838 -> 1574 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bKce535808c0f555491d6099c46f253abf
1438858838 -> 21b3 [CTransaction::CTransaction] Transaction is cloned in 4 state
1438858838 -> 1574 [CDialog::addTransaction] added transaction 21b3 with branch z9hG4bKce535808c0f555491d6099c46f253abf, with CSeq 1033640799
1438858838 -> 1574 [CDialog::startDialogTTL]
1438858838 -> 1574 [CDialog::receiveResponse]
1438858838 -> 21b3 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1438858838 -> 21b3 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1438858838 -> 21b3 [CTransaction::changeState] notifying the parent dialog
1438858838 -> 1574 [CDialog::onTransactionState(pTrans = 21b3, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
1438858838 -> 21b3 [CTransaction::startTimer] Timer D is started (delay = 32165 ms)
1438858838 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
1438858842 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1438858842 -> [CSessionTimerContext::updateSupported] Request timer supported
1438858842 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1438858842 -> [CSessionTimerContext::updateSessionExpires] header value : 1800
1438858842 -> [CSessionTimerContext::updateSessionExpires] updated
1438858842 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1438858842 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1438858842 -> [CSessionTimerContext::updateAfterResponseRefreshReception] Update CSessionTimerContext (response refresh reception)
1438858842 -> [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
1438858842 -> [CSessionTimerContext::startTimers] Start session timer will expires : 900000
1438858842 -> [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=INVITE
1438858842 -> 1574 [CDialog::updateRouteSet] there are 0 record-route headers
1438858842 -> 1130 [CCall::insertInDialogMap] added dialog #1574 with the key 30592e426cd4efc607af604150e3ba54;783B5BD69270
1438858842 -> 1573 [CDialog::getTransactionByCSeq] CSeq = 1033640800
1438858842 -> 1573 [CDialog::updateRouteSet] there are 0 record-route headers
1438858842 -> 1130[CMotorCall::searchForkedBranch]pForkedBranch=0xce77740.
1438858842 -> [CForkedBranch::setFinalResponse] pResponse=0xce78ca0.
1438858842 -> [CForkedBranch::setFinalResponse] response=200.
1438858842 -> 1130[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
1438858842 -> 1130[CMotorCall::chooseBestResponse] pForkedBranch=0xce77740 iResponseCode=2000.
1438858842 -> [CForkedBranch::getResponseCode] response=200.
1438858842 -> 1130[CMotorCall::chooseBestResponse] last iResponseCode=200.
1438858842 -> 1130[CMotorCall::chooseBestResponse] next branch.
1438858842 -> 1130[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
1438858842 -> [receiveSuccessfulMessage] Call: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 eqt: 3292 PROCEEDING_STATE received a message.
1438858842 -> 1130[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
1438858842 -> [checkSdpValidity] Sdp contains 1 media description(s).
1438858842 -> [checkSdpValidity] Media 0 type 1 contains 2 formats.
1438858842 -> [checkSdpValidity] Format : 18.
1438858842 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1438858842 -> [convertSdpIntoTsdp] default T38 config.
1438858842 -> [convertSdpIntoTsdp] No Direction in the session part.
1438858842 -> [convertSdpIntoTsdp] Check the direction in Session part - result:0.
1438858842 -> [convertSdpIntoTsdp] The audio media contains 2 format(s).
1438858842 -> [convertSdpIntoTsdp] Format 0 is 18.
1438858842 -> [convertSdpIntoTsdp] Format 1 is 101.
1438858842 -> [convertSdpIntoTsdp] Get the direction.
1438858842 -> [convertSdpIntoTsdp] Direction is sendrecv.
1438858842 -> [convertSdpIntoTsdp] The connection is at session level.
1438858842 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 10.235.96.150.
1438858842 -> [convertIPStrIntoTuipv] 10.235.96.150 => 10.235.96.150
1438858842 -> [methodAllowedByDistant] INFO not allowed by distant !!
1438858842 -> 1130[emitEventToMonitel] content size (lginfo): 656
1438858842 -> 1130[emitEventToMonitel] CAC = 0 eqtCAC = -1
1438858842 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858846 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858846 -> [sendLgEvtSip] Event sent on eqt : 3292 Id :-1
1438858846 -> [display_ipc_out] ------------ Begin ---------------
1438858846 -> Id : -1
1438858846 -> SUCCESSFUL
1438858846 -> xx : 0
1438858846 -> RELATIVE REQUEST : INVITE
1438858846 -> CLIR : 0
1438858846 -> COLP : 0
1438858846 -> SDP :
1438858846 -> ADDRESS : 10.235.96.150 :54596
1438858846 -> ALGOS :
1438858846 -> G729
1438858846 -> DIRECTION : SEND & RECEIVE
1438858846 -> [display_ipc_out] ------------- End ----------------
1438858846 -> [receiveSuccessfulMessage] SRV_OK received update FROM TAG on the StandBy.
1438858846 -> 1130 [CCall::getCallDuplicationData]
1438858846 -> 1130 [CCall::getCallDuplicationData] : Request URI = , Call ID = 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130, Local URI = sip:505886@10.235.96.130;user=phone, Local Tag = 30592e426cd4efc607af604150e3ba54, Remote URI = sip:38982000@10.235.96.150:5061;user=phone, Remote Tag = 783B5BD69270, Local CSeq = 1033640799, Remote CSeq = 0
1438858846 -> [CViaSetSerializer::serialize] Serialized via set :
1438858846 -> [CRouteSet::serialize] Serialized route set : Contact=sip:38982000@10.235.96.150:5061;user=phone
1438858846 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858846 -> 1130[CMotorCall::getOutgoingCall] outgoingCall:1
1438858846 -> 1130[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1438858846 -> 1130[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1438858846 -> [CForkedBranch::getResponseCode] response=200.
1438858846 -> [exec_ipc] in 1744.
1438858846 -> [display_ipc_in] ------------ Begin ---------------
1438858846 -> neqt : 3292 Id : -1
1438858846 -> ACK
1438858846 -> [display_ipc_in] ------------- End ----------------
1438858846 -> [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 3292--1.
1438858846 -> [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
1438858846 -> [onIncomingEvent] ACK arrived.
1438858846 -> [receiveAckEvent] Call: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 eqt: 3292 ACCEPTED_STATE received an event.
1438858846 -> [isValidGwExt] ext gw 1 is valid
1438858846 -> 1130[CMotorCall::inviteBuildContact] Contact: sip:10.235.96.130
1438858846 -> 1130[CMotorCall::emitAckMessage] begin.
1438858846 -> 1130[CMotorCall::emitAckMessage] SDP ok.
1438858846 -> 1130 [CCall::makeGenericRequest] ACK
1438858846 -> 1130 [CCall::getDialog] Confirmed Dialog found
1438858846 -> 1574 [CDialog::createRequest]
1438858846 -> 1574 [CDialog::buildServicesForAllRequest]
1438858846 -> 1574 [CDialog::createAckRequest]
1438858846 -> 1574 [CDialog::createAckRequest], previous trans 21b3 is found
1438858846 -> 1574 [CDialog::createAckRequest], previous trans 21b3 is client
1438858846 -> 2FE8 [CRequest::CRequest] Creation of a request
1438858846 -> 1574 [CDialog::buildServicesForAck]
1438858846 -> 2FE8 [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858846 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 495)
ACK sip:38982000@10.235.96.150:5061;user=phone SIP/2.0Contact: sip:10.235.96.130User-Agent: OmniPCX Enterprise R9.1 i1.605.38To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=783B5BD69270From: "" <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640799 ACKVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK26d7529f2be20315b65ec653fecd6481Max-Forwards: 70Content-Length: 0-------------------------------------------------
1438858850 -> 21b3 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858850 -> 21b3 [CTransaction::freeTimerToken] Timer D is freed
1438858850 -> 21b3 [CTransaction::changeState] no transaction state, terminated reason : Request creation
1438858850 -> 1574 [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
1438858850 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858850 -> 1130 [CCall::getCallDuplicationData]
1438858850 -> 1130 [CCall::getCallDuplicationData] : Request URI = , Call ID = 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130, Local URI = sip:505886@10.235.96.130;user=phone, Local Tag = 30592e426cd4efc607af604150e3ba54, Remote URI = sip:38982000@10.235.96.150:5061;user=phone, Remote Tag = 783B5BD69270, Local CSeq = 1033640799, Remote CSeq = 0
1438858850 -> [CViaSetSerializer::serialize] Serialized via set :
1438858850 -> [CRouteSet::serialize] Serialized route set : Contact=sip:38982000@10.235.96.150:5061;user=phone
1438858850 -> [exec_ipc] in end 1744.
1438858850 -> [CTransaction::notifyDialog]
1438858850 -> [CTransaction::notifyDialog] notify parent dialog
1438858850 -> 1574 [CDialog::onTransactionState(pTrans = 21b3, previousState = null, currentState = Terminated, reason = Request creation]
1438858850 -> 21B3 [~CTransaction] transaction 1033640799 INVITE
1438858850 -> 21b0 [CTransCompletedState::timerFires] Timer J fires
1438858850 -> 21b0 [CTransCompletedState::timerFires] Timer J : Transaction changes to Terminated state
1438858850 -> 21b0 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858850 -> 21b0 [CTransaction::changeState] no transaction state, terminated reason : Timer J fires
1438858850 -> 1571 [CDialog::onTransactionState(pTrans = 21b0, previousState = null, currentState = Terminated, reason = Timer J fires]
1438858850 -> 1571 [CDialog::onTransactionState] dialog is terminated
1438858850 -> 1571 [CDialog::onTransactionState] onDialogClosed
1438858850 -> 112e [CCall::onDialogClosed]
1438858850 -> 112e [CCall::onDialogClosed] only initial *********
1438858850 -> 112e [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1438858850 -> 112e [CCall] closed
1438858850 -> 104 [CCallManager::onCallClosed]
1438858850 -> 104 [CCallManager::onCallClosed()] Call 112e closed. Removing call 216388464 from the maps
1438858850 -> 21B0 [~CTransaction] transaction 806 REGISTER
1438858850 -> 21b1 [CTransCompletedState::timerFires] Timer J fires
1438858850 -> 21b1 [CTransCompletedState::timerFires] Timer J : Transaction changes to Terminated state
1438858850 -> 21b1 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858850 -> 21b1 [CTransaction::changeState] no transaction state, terminated reason : Timer J fires
1438858850 -> 1572 [CDialog::onTransactionState(pTrans = 21b1, previousState = null, currentState = Terminated, reason = Timer J fires]
1438858850 -> 1572 [CDialog::onTransactionState] dialog is terminated
1438858850 -> 1572 [CDialog::onTransactionState] onDialogClosed
1438858850 -> 112f [CCall::onDialogClosed]
1438858850 -> 112f [CCall::onDialogClosed] only initial *********
1438858850 -> 112f [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1438858850 -> 112f [CCall] closed
1438858850 -> 104 [CCallManager::onCallClosed()] Call 112f closed. Removing call 216375336 from the maps
1438858850 -> 21B1 [~CTransaction] transaction 806 REGISTER
1438858854 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
INVITE sip:505886@10.235.96.130 SIP/2.0Via: SIP/2.0/UDP 10.235.96.150:5061From: <sip:38982000@10.235.96.150:5061;user=phone>;tag=783B5BD69270To: <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640800 INVITEMax-Forwards: 70Contact: <sip:38982000@10.235.96.150:5061;user=phone>User-Agent: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Type: application/sdpContent-Length: 288v=0o=XMedius-Fax-Gateway 39514127 128 IN IP4 10.235.96.150s=absc=IN IP4 10.235.96.150t=0 0m=image 44374 udptl t38a=T38FaxVersion:0a=T38maxBitRate:14400a=T38FaxRateManagement:transferredTCFa=T38FaxMaxBuffer:8192a=T38FaxMaxDatagram:1008a=T38FaxUdpEC:t38UDPRedundancy-------------------------------------------------
1438858854 -> 2FE9 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1438858854 -> 21b4 [CTransConfirmedState::timerFires] Timer I fires
1438858854 -> 21b4 [CTransConfirmedState::timerFires] TimerI : Transaction changes to Terminated state
1438858854 -> 21b4 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858854 -> 21b4 [CTransaction::changeState] no transaction state, terminated reason : Timer I fires
1438858854 -> [CTransaction::notifyDialog]
1438858854 -> [CTransaction::notifyDialog] notify parent dialog
1438858854 -> 1574 [CDialog::onTransactionState(pTrans = 21b4, previousState = null, currentState = Terminated, reason = Timer I fires]
1438858854 -> 21B4 [~CTransaction] transaction 1033640800 INVITE
1438858854 -> 2FEA [~CRequest] req 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640800 ACK
1438858854 -> EAu: Block Memory Size: 82900
1438858854 -> EAu: Dupli window: 0/1 (max: 0)
1438858854 -> ascii.alarm.delay = 4h
1438858854 -> cl_daCalendar::dayOfWeek
1438858854 -> cl_daCalendar::dayType
1438858854 -> nbDays = 5
1438858854 -> clock=18748800 (1970/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858854 -> clock=18748800 (1970/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858854 -> clock=1438815600 (2015/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858854 -> clock=1438815600 (2015/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858854 -> clock=1438815600 (2015/08/06), nwd[4].time=1106175600 (2005/01/20) [min=4, max=4]
1438858854 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858854 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858854 -> [exec_ipc] in 1744.
1438858854 -> [display_ipc_in] ------------ Begin ---------------
1438858854 -> neqt : 3292 Id : -1
1438858854 -> BYE
1438858854 -> [display_ipc_in] ------------- End ----------------
1438858854 -> [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 3292--1.
1438858854 -> [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
1438858854 -> [onIncomingEvent] BYE arrived.
1438858854 -> [receiveByeEvent] Call: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 eqt: 3292 COMPLETED_STATE received an event.
1438858854 -> [isValidGwExt] ext gw 1 is valid
1438858854 -> 1130[CMotorCall ABCF ExtGW
1438858854 -> 1130 [CCall::makeGenericRequest] BYE
1438858854 -> 1130 [CCall::getDialog] Confirmed Dialog found
1438858854 -> 1574 [CDialog::createRequest]
1438858854 -> 1574 [CDialog::buildServicesForAllRequest]
1438858854 -> 1574 [CDialog::createByeRequest]
1438858858 -> 21b5 [CTransaction::changeState] STATE CHANGED TO INITIAL
1438858858 -> 21b5 [CTransaction::changeState] notifying the parent dialog
1438858858 -> 1574 [CDialog::onTransactionState(pTrans = 21b5, previousState = Terminated, currentState = Initial, reason = None]
1438858858 -> 2FEB [CRequest::CRequest] Creation of a request
1438858858 -> 2FEB [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858858 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 483)
BYE sip:38982000@10.235.96.150:5061;user=phone SIP/2.0Supported: replaces,timer,100relUser-Agent: OmniPCX Enterprise R9.1 i1.605.38To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=783B5BD69270From: <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640800 BYEVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK09fa383405e5a0f0d4d396acdfa3db7dMax-Forwards: 70Content-Length: 0-------------------------------------------------
1438858858 -> 21b5 [CTransInitialState::createRequest] Transaction changes to Trying state
1438858858 -> 21b5 [CTransaction::changeState] STATE CHANGED TO TRYING
1438858858 -> 1574 [CDialog::onTransactionState(pTrans = 21b5, previousState = Initial, currentState = Trying, reason = Request creation]
1438858858 -> 21b5 [CTransTryingState::enterInState] Init timers E and F
1438858858 -> 21b5 [CTransaction::startTimer] Timer E is started (delay = 500 ms)
1438858858 -> 21b5 [CTransaction::startTimer] Timer F is started (delay = 32000 ms)
1438858858 -> 1574 [CDialog::addTransaction] added transaction 21b5 with branch z9hG4bK09fa383405e5a0f0d4d396acdfa3db7d, with CSeq 1033640800
1438858858 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1438858858 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858858 -> [exec_ipc] in end 1744.
1438858858 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
SIP/2.0 200 OKVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK09fa383405e5a0f0d4d396acdfa3db7dFrom: <sip:505886@10.235.96.130;user=phone>;tag=30592e426cd4efc607af604150e3ba54To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=783B5BD69270Call-ID: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130CSeq: 1033640800 BYEAllow: INVITE, ACK, BYE, CANCELContact: <sip:38982000@10.235.96.150:5061;user=phone>Server: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Length: 0-------------------------------------------------
1438858858 -> [CIOCom::receiveResponse] CResponse 2C9E ref=1
1438858858 -> [CDispatcher::onIncomingResponse]
1438858858 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1438858858 -> 102 [CCallManager::onIncomingResponse]
1438858858 -> 1130 [CCall::receiveResponse] 200
1438858858 -> 1130 [CCall::receiveResponse]Trying to find the right dialog
1438858858 -> 1130 [CCall::getDialog] Confirmed Dialog found
1438858858 -> 1130 [CCall::receiveResponse]One dialog found
1438858858 -> 1574 [CDialog::receiveResponse]
1438858858 -> 21b5 [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
1438858858 -> 21b5 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1438858858 -> 1574 [CDialog::onTransactionState(pTrans = 21b5, previousState = Trying, currentState = Completed, reason = Final resp reception]
1438858858 -> 21b5 [CTransaction::freeTimerToken] Timer E is freed
1438858858 -> 21b5 [CTransaction::freeTimerToken] Timer F is freed
1438858858 -> 21b5 [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
1438858866 -> 1130[CMotorCall::onReceiveResponse] Update2 the Other context.
1438858866 -> [receiveSuccessfulMessage] Call: 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 eqt: 3292 TERMINATED_STATE received a message.
1438858866 -> 1130[emitEventToMonitel] content size (lginfo): 656
1438858866 -> 1130[emitEventToMonitel] CAC = 0 eqtCAC = -1
1438858866 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858866 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858866 -> [sendLgEvtSip] Event sent on eqt : 3292 Id :-1
1438858866 -> [display_ipc_out] ------------ Begin ---------------
1438858866 -> Id : -1
1438858866 -> SUCCESSFUL
1438858866 -> xx : 0
1438858866 -> RELATIVE REQUEST : BYE
1438858866 -> CLIR : 0
1438858866 -> COLP : 0
1438858866 -> [display_ipc_out] ------------- End ----------------
1438858866 -> [exec_ipc] in 1744.
1438858866 -> [display_ipc_in] ------------ Begin ---------------
1438858866 -> neqt : 3292 Id : -1
1438858866 -> SIP EQT RELEASED
1438858866 -> [display_ipc_in] ------------- End ----------------
1438858866 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 3292--1.
1438858866 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 3292 has released its equipment.
1438858866 -> 1130[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1438858866 -> SIP_EQT_RELEASE_ACK
1438858866 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1438858866 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858866 -> 1130[CMotorCall::unRegister] Remove eqt : 3292 diag : -1 from the map.
1438858866 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 3292 erased.
1438858866 -> [CMotorCallManager::onIncomingEvent] killSession.
1438858866 -> 1130 [CCall::killSession]
1438858866 -> 21b2 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858866 -> 21b2 [CTransaction::changeState] no transaction state, terminated reason : None
1438858866 -> 21b5 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858866 -> 21b5 [CTransaction::freeTimerToken] Timer K is freed
1438858866 -> 21b5 [CTransaction::changeState] no transaction state, terminated reason : None
1438858866 -> 1130 [CCall::onKill Session Call manager close is called]
1438858866 -> 1130 [CCall::killSession] notifying the call manager
1438858866 -> 102 [CCallManager::onCallClosed]
1438858866 -> 102 [CCallManager::onCallClosed()] Call 1130 closed. Removing call 216474088 from the maps
1438858866 -> [CMotorCallManager::onNotifyCallClosed] Call : 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 is closed.
1438858866 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1438858866 -> [CCall::onKill] set callmanager to null
1438858866 -> [exec_ipc] in end 1744.
1438858866 -> [CTransaction::notifyDialog]
1438858866 -> [CTransaction::notifyDialog] notify parent dialog
1438858866 -> 1573 [CDialog::onTransactionState(pTrans = 21b2, previousState = null, currentState = Terminated, reason = None]
1438858866 -> 1573 [CDialog::onTransactionState] dialog is terminated
1438858866 -> 1573 [CDialog::onTransactionState] onDialogClosed
1438858866 -> 1130 [CCall::onDialogClosed]
1438858870 -> 1130 [CCall::onDialogClosed] not only initial *********
1438858870 -> 1130 [CCall::onDialogClosed]: the dialog 1574 is NOT closed
1438858870 -> 21B2 [~CTransaction] transaction 1033640799 INVITE
1438858870 -> 2C9A [~CResponse] resp(100) 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640799 INVITE
1438858870 -> [CTransaction::notifyDialog]
1438858870 -> [CTransaction::notifyDialog] notify parent dialog
1438858870 -> 1574 [CDialog::onTransactionState(pTrans = 21b5, previousState = null, currentState = Terminated, reason = None]
1438858870 -> 1130 [CCall::onDialogClosed]: the dialog 1574 is closed
1438858870 -> 1130 [CCall::onDialogClosed] All the dialogs in the Call are closed
1438858870 -> 21B5 [~CTransaction] transaction 1033640800 BYE
1438858870 -> 2C9E [~CResponse] resp(200) 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640800 BYE
1438858870 -> 102 [CCallManager::removeGarbage] at index i = 0
1438858870 -> 1130[CMotorCall::~CMotorCall] Call : 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 is being destructed.
1438858870 -> 1130 [CCall::~CCall]
1438858870 -> 1130 [CCall::removeGarbage]
1438858870 -> 1574 [CDialog::~CDialog]
1438858870 -> 1574 [~CDialog] delete ack request # 0
1438858870 -> 2FE8 [~CRequest] req 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640799 ACK
1438858870 -> 2C9B [~CResponse] resp(200) 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640799 INVITE
1438858870 -> 1573 [CDialog::~CDialog]
1438858870 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1438858870 -> 2FE7 [~CRequest] req 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640799 INVITE
1438858870 -> 2FEB [~CRequest] req 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640800 BYE
1438858870 -> 2C9D [~CResponse] resp(200) 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640800 INVITE
1438858870 -> 2FE9 [~CRequest] req 3090c8c7769bb9f83cf4bd3774cd2e73@10.235.96.130 1033640800 INVITE
1438858870 -> EAu: Block Memory Size: 82900
1438858870 -> EAu: Dupli window: 0/1 (max: 0)
1438858870 -> main.trace.timer = 480mn
1438858870 -> cl_daCalendar::dayOfWeek
1438858870 -> cl_daCalendar::dayType
1438858870 -> nbDays = 5
1438858870 -> clock=18748800 (1970/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858870 -> clock=18748800 (1970/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858870 -> clock=1438815600 (2015/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858870 -> clock=1438815600 (2015/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858870 -> clock=1438815600 (2015/08/06), nwd[4].time=1106175600 (2005/01/20) [min=4, max=4]
1438858873 -> EAu: Block Memory Size: 82900
1438858873 -> EAu: Dupli window: 0/1 (max: 0)
1438858883 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858883 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858883 -> [exec_ipc] in 1744.
1438858883 -> [display_ipc_in] ------------ Begin ---------------
1438858883 -> neqt : 3292 Id : -1
1438858883 -> INVITE
1438858883 -> REQUEST URI : <> 38982000@10.235.96.150:5061 ; user=phone
1438858883 -> FROM : <> 505886@10.235.96.130:5060 ; user=phone
1438858883 -> TO : <> 38982000@10.235.96.150:5061 ; user=phone
1438858883 -> CAC : 0
1438858883 -> neqt CAC : -1
1438858883 -> CLIR : 0
1438858883 -> SDP :
1438858883 -> ADDRESS : 10.235.96.147 :32140
1438858883 -> ALGOS :
1438858883 -> G729
1438858883 -> G723
1438858883 -> PCMA
1438858883 -> 97
1438858883 -> DIRECTION : SEND & RECEIVE
1438858883 -> N_GW_EXT : 1
1438858883 -> [display_ipc_in] ------------- End ----------------
1438858883 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 3292--1.
1438858883 -> [CMotorCallManager::onIncomingEvent] New Call created.
1438858883 -> [CMotorCallManager::callFactory].
1438858883 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R9.1 i1.605.38
1438858883 -> [CMotorCallManager::callFactory]=ce71468.
1438858883 -> [CMotorCallManager::onIncomingEvent] eqt=3292 -1.
1438858883 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 3292 inserted.
1438858883 -> [quoteString] => ""
1438858883 -> 1131[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
1438858883 -> 1131[CMotorCall::setFilterUsedMode] To be traced = 0
1438858883 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1438858883 -> [onIncomingEvent] INVITE arrived.
1438858883 -> [receiveInviteEvent] Call: eqt: 3292 INITIAL_STATE received an event.
1438858883 -> 1131[CMotorCall::emitInviteMessage] begin.
1438858883 -> [isValidGwExt] ext gw 1 is valid
1438858883 -> 1131[CMotorCall::inviteBuildAurlWithBelongingDomain] extGw=1
1438858883 -> [is_addr_in_dico] user=38982000 host=10.235.96.150
1438858883 -> [isUserDeclared] 38982000@10.235.96.150
1438858883 -> [isUserDeclared] found in the dictionnary.
1438858883 -> [is_addr_in_dico] other sip user
1438858883 -> 1131[CMotorCall::inviteBuildAurlWithoutBelongingDomain] P-Asserted-Identity: "" <sip:505886@10.235.96.130;user=phone>
1438858883 -> 1131[CMotorCall::emitInviteMessage] From: "" <sip:505886@10.235.96.130;user=phone>
1438858883 -> 1131[CMotorCall::emitInviteMessage] reqUri :sip:38982000@10.235.96.150:5061;user=phone
1438858883 -> 1131[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1
1438858883 -> 1131[CMotorCall ABCF ExtGW
1438858883 -> 1131[CMotorCall::inviteBuildSupportedHeader] Invite directed to external gw : 1
1438858883 -> 1131[CMotorCall::emitInviteMessage] Request Uri : sip:38982000@10.235.96.150:5061;user=phone
1438858883 -> 1131[CMotorCall::emitInviteMessage] To: <sip:38982000@10.235.96.150:5061;user=phone>
1438858883 -> am_I_PCS SCSWorking : NO
1438858883 -> check_PCSstate
1438858883 -> check_PCSstate stat of PCS is : -1
1438858883 -> 1131[CMotorCall::inviteBuildContact] begin. crms00137339
1438858883 -> [137339 - inviteBuildContact] trunk_number=1799 extGw =1.
1438858883 -> [137339-InviteBuildContact] userinfo : 505886
1438858883 -> 1131[CMotorCall::inviteBuildContact] Contact: sip:505886@10.235.96.130
1438858883 -> 1131[CMotorCall::emitInviteMessage] uacGatewayMode=1 uacRefresher=1.
1438858883 -> 1131[CMotorCall::makeRequestSdp] Begin sdp.
1438858883 -> 1131[CMotorCall::makeRequestSdp] Direction: 0.
1438858883 -> 1131[CMotorCall::makeRequestSdp] format 97
1438858883 -> 1131[CMotorCall::makeRequestSdp] Final sdp.
1438858883 -> 1131[CMotorCall::emitInviteMessage] The sdp build.
1438858887 -> 1131[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] isResolution=0.
1438858887 -> [isValidGwExt] ext gw 1 is valid
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] target is not the local node.
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 38982000
1438858887 -> [isUserDeclared] 38982000@10.235.96.150
1438858887 -> [isUserDeclared] found in the dictionnary.
1438858887 -> [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest]-->extGw=1
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] contact : sip:38982000@10.235.96.150:5061;user=phone
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] nb available licenses=14 .
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=10.235.96.150
1438858887 -> 1131[CMotorCall::makeInitialMotorRequest] user= 38982000
1438858887 -> [CGWMngData::isMainServer] CPU is MAIN.
1438858887 -> [CGWMngData::isMainServer] checkwith PCS = 0
1438858887 -> [CMotorCall::makeInitialMotorRequest] count = 3.
1438858887 -> [CMotorCall::makeInitialMotorRequest] service=0 0xbffff0b8.
1438858887 -> [CMotorCall::makeInitialMotorRequest] service=1 0xbfffed58.
1438858887 -> [CMotorCall::makeInitialMotorRequest] service=2 0xbfffe73c.
1438858887 -> 1131 [CCall::makeGenericRequest] INVITE
1438858887 -> 1131 [CCall::getDialog] Confirmed Dialog is not found (ID = ;)
1438858887 -> 1131 [CCall::getDialog] Initial Dialog Client not found
1438858887 -> 1575 [CDialog::createRequest]
1438858887 -> 1575 [CDialog::buildServicesForAllRequest]
1438858887 -> 1575 [CDialog::createInviteRequest]
1438858887 -> 21b6 [CTransaction::changeState] STATE CHANGED TO INITIAL
1438858887 -> 21b6 [CTransaction::changeState] notifying the parent dialog
1438858887 -> 1575 [CDialog::onTransactionState(pTrans = 21b6, previousState = Terminated, currentState = Initial, reason = None]
1438858887 -> 2FEC [CRequest::CRequest] Creation of a request
1438858887 -> 2FEC [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858887 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 1131)
INVITE sip:38982000@10.235.96.150:5061;user=phone SIP/2.0Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFOSupported: replaces,timer,100relUser-Agent: OmniPCX Enterprise R9.1 i1.605.38Session-Expires: 1800;refresher=uacMin-SE: 900P-Asserted-Identity: "" <sip:505886@10.235.96.130;user=phone>Content-Type: application/sdpTo: <sip:38982000@10.235.96.150:5061;user=phone>From: "" <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6Contact: <sip:505886@10.235.96.130;transport=UDP>Call-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974466 INVITEVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK950cc323d3352ecc3997f2f4802ee018Max-Forwards: 70Content-Length: 341v=0o=OXE 1438858883 1438858883 IN IP4 10.235.96.130s=absc=IN IP4 10.235.96.147t=0 0m=audio 32140 RTP/AVP 18 4 8 97a=sendrecva=rtpmap:18 G729/8000a=fmtp:18 annexb=noa=ptime:20a=maxptime:40a=rtpmap:4 G723/8000a=ptime:30a=maxptime:30a=rtpmap:8 PCMA/8000a=ptime:20a=maxptime:30a=rtpmap:97 telephone-event/8000-------------------------------------------------
1438858887 -> 21b6 [CTransInitialState::createRequest] Transaction changes to Calling state
1438858891 -> 21b6 [CTransaction::changeState] STATE CHANGED TO CALLING
1438858891 -> 21b6 [CTransaction::changeState] notifying the parent dialog
1438858891 -> 1575 [CDialog::onTransactionState(pTrans = 21b6, previousState = Initial, currentState = Calling, reason = Request creation]
1438858891 -> 21b6 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
1438858891 -> 21b6 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
1438858891 -> 1575 [CDialog::getTransactionByCSeq] CSeq = 956974466
1438858891 -> 1575 [CDialog::addTransaction] added transaction 21b6 with branch z9hG4bK950cc323d3352ecc3997f2f4802ee018, with CSeq 956974466
1438858891 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
1438858891 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1438858891 -> [CSessionTimerContext::updateSupported] Request timer supported
1438858891 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1438858891 -> [CSessionTimerContext::updateSessionExpires] header value : 1800
1438858891 -> [CSessionTimerContext::updateSessionExpires] updated
1438858891 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1438858891 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1438858891 -> 1131[CMotorCall::makeInitialMotorRequest] nb contact=1.
1438858891 -> [CForkedBranch::CForkedBranch] context = 0xce718d0.
1438858891 -> 1131[CMotorCall::branchAllocation] built branch number=1.
1438858891 -> 1131[CMotorCall::branchAllocation] pForkedBranch = 0xce73198.
1438858891 -> 1131[CMotorCall::makeInitialMotorRequest] reqUri duplication pForkedBranch = 0xce73198.
1438858891 -> 1131[CMotorCall::makeInitialMotorRequest] reqUri duplication2.
1438858891 -> 1131[CMotorCall::getOutgoingCall] outgoingCall:1
1438858891 -> 1131 [CCall::getCallDuplicationData]
1438858891 -> [CViaSetSerializer::copy] Added via 7cc4 at index 0
1438858891 -> 1131 [CCall::getCallDuplicationData] : Request URI = sip:38982000@10.235.96.150:5061;user=phone, Call ID = 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130, Local URI = sip:505886@10.235.96.130;user=phone, Local Tag = 41117bc11aa2b644d28b9fa5fbf8c8e6, Remote URI = sip:38982000@10.235.96.150:5061;user=phone, Remote Tag = , Local CSeq = 956974466, Remote CSeq = 0
1438858891 -> [CViaSetSerializer::serialize] Serialized via set : ViaSerialize=Via: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK950cc323d3352ecc3997f2f4802ee018
1438858891 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858891 -> [onIncomingEvent] CallID must be inserted.
1438858891 -> [onIncomingEvent] CallID inserted.
1438858891 -> [exec_ipc] in end 1744.
1438858891 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
SIP/2.0 100 TryingVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK950cc323d3352ecc3997f2f4802ee018From: "" <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6To: <sip:38982000@10.235.96.150:5061;user=phone>Call-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974466 INVITEAllow: INVITE, ACK, BYE, CANCELContact: <sip:38982000@10.235.96.150:5061;user=phone>Server: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Length: 0-------------------------------------------------
1438858891 -> [CIOCom::receiveResponse] CResponse 2C9F ref=1
1438858891 -> [CDispatcher::onIncomingResponse]
1438858891 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1438858891 -> 102 [CCallManager::onIncomingResponse]
1438858891 -> 1131 [CCall::receiveResponse] 100
1438858891 -> 1131 [CCall::receiveResponse]Trying to find the right dialog
1438858895 -> 1131 [CCall::getDialog] Confirmed Dialog is not found (ID = 41117bc11aa2b644d28b9fa5fbf8c8e6;)
1438858895 -> 1131 [CCall::getDialog] Returning Initial Dialog Client
1438858895 -> 1131 [CCall::receiveResponse]One dialog found
1438858895 -> 1575 [CDialog::receiveResponse]
1438858895 -> 21b6 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
1438858895 -> 21b6 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1438858895 -> 21b6 [CTransaction::changeState] notifying the parent dialog
1438858895 -> 1575 [CDialog::onTransactionState(pTrans = 21b6, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
1438858895 -> 21b6 [CTransaction::freeTimerToken] Timer A is freed
1438858895 -> 21b6 [CTransaction::freeTimerToken] Timer B is freed
1438858895 -> 1131[CMotorCall::searchForkedBranch]pForkedBranch=0xce73198.
1438858895 -> [receiveInformationalMessage] Call: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 eqt: 3292 PROCEEDING_STATE received a message.
1438858895 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
SIP/2.0 200 OKVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK950cc323d3352ecc3997f2f4802ee018From: "" <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=F4ED6EF3F34ACall-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974466 INVITEAllow: INVITE, ACK, BYE, CANCELContact: <sip:38982000@10.235.96.150:5061;user=phone>Server: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Type: application/sdpContent-Length: 186v=0o=XMedius-Fax-Gateway 39566791 791 IN IP4 10.235.96.150s=absc=IN IP4 10.235.96.150t=0 0m=audio 38082 RTP/AVP 18 101a=sendrecva=rtpmap:18 G729/8000a=fmtp:18 annexb=no-------------------------------------------------
1438858895 -> [CIOCom::receiveResponse] CResponse 2CA0 ref=1
1438858895 -> [CDispatcher::onIncomingResponse]
1438858895 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1438858895 -> 102 [CCallManager::onIncomingResponse]
1438858895 -> 1131 [CCall::receiveResponse] 200
1438858895 -> 1131 [CCall::receiveResponse]Trying to find the right dialog
1438858895 -> 1131 [CCall::getDialog] Confirmed Dialog is not found (ID = 41117bc11aa2b644d28b9fa5fbf8c8e6;F4ED6EF3F34A)
1438858895 -> 1575 [CDialog::receiveResponse] create a CONFIRMED dialog
1438858895 -> 1576 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bK950cc323d3352ecc3997f2f4802ee018
1438858895 -> 1576 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bK950cc323d3352ecc3997f2f4802ee018
1438858895 -> 21b7 [CTransaction::CTransaction] Transaction is cloned in 4 state
1438858895 -> 1576 [CDialog::addTransaction] added transaction 21b7 with branch z9hG4bK950cc323d3352ecc3997f2f4802ee018, with CSeq 956974466
1438858895 -> 1576 [CDialog::startDialogTTL]
1438858895 -> 1576 [CDialog::receiveResponse]
1438858895 -> 21b7 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
1438858895 -> 21b7 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1438858895 -> 21b7 [CTransaction::changeState] notifying the parent dialog
1438858895 -> 1576 [CDialog::onTransactionState(pTrans = 21b7, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
1438858895 -> 21b7 [CTransaction::startTimer] Timer D is started (delay = 32351 ms)
1438858895 -> [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
1438858899 -> [CSessionTimerContext::updateAfterRefreshCreation] Update CSessionTimerContext (refresh creation)
1438858899 -> [CSessionTimerContext::updateSupported] Request timer supported
1438858899 -> [CSessionTimerContext::updateMinSE] Min-SE updated : 900
1438858899 -> [CSessionTimerContext::updateSessionExpires] header value : 1800
1438858899 -> [CSessionTimerContext::updateSessionExpires] updated
1438858899 -> [CSessionTimerContext::updateSessionExpires] Refresher updated : i
1438858899 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1438858899 -> [CSessionTimerContext::updateAfterResponseRefreshReception] Update CSessionTimerContext (response refresh reception)
1438858899 -> [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
1438858899 -> [CSessionTimerContext::startTimers] Start session timer will expires : 900000
1438858899 -> [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=INVITE
1438858899 -> 1576 [CDialog::updateRouteSet] there are 0 record-route headers
1438858899 -> 1131 [CCall::insertInDialogMap] added dialog #1576 with the key 41117bc11aa2b644d28b9fa5fbf8c8e6;F4ED6EF3F34A
1438858899 -> 1575 [CDialog::getTransactionByCSeq] CSeq = 956974467
1438858899 -> 1575 [CDialog::updateRouteSet] there are 0 record-route headers
1438858899 -> 1131[CMotorCall::searchForkedBranch]pForkedBranch=0xce73198.
1438858899 -> [CForkedBranch::setFinalResponse] pResponse=0xce79758.
1438858899 -> [CForkedBranch::setFinalResponse] response=200.
1438858899 -> 1131[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
1438858899 -> 1131[CMotorCall::chooseBestResponse] pForkedBranch=0xce73198 iResponseCode=2000.
1438858899 -> [CForkedBranch::getResponseCode] response=200.
1438858899 -> 1131[CMotorCall::chooseBestResponse] last iResponseCode=200.
1438858899 -> 1131[CMotorCall::chooseBestResponse] next branch.
1438858899 -> 1131[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
1438858899 -> [receiveSuccessfulMessage] Call: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 eqt: 3292 PROCEEDING_STATE received a message.
1438858899 -> 1131[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
1438858899 -> [checkSdpValidity] Sdp contains 1 media description(s).
1438858899 -> [checkSdpValidity] Media 0 type 1 contains 2 formats.
1438858899 -> [checkSdpValidity] Format : 18.
1438858899 -> [convertSdpIntoTsdp] Sdp contains 1 media description(s).
1438858899 -> [convertSdpIntoTsdp] default T38 config.
1438858899 -> [convertSdpIntoTsdp] No Direction in the session part.
1438858899 -> [convertSdpIntoTsdp] Check the direction in Session part - result:0.
1438858899 -> [convertSdpIntoTsdp] The audio media contains 2 format(s).
1438858899 -> [convertSdpIntoTsdp] Format 0 is 18.
1438858899 -> [convertSdpIntoTsdp] Format 1 is 101.
1438858899 -> [convertSdpIntoTsdp] Get the direction.
1438858899 -> [convertSdpIntoTsdp] Direction is sendrecv.
1438858899 -> [convertSdpIntoTsdp] The connection is at session level.
1438858899 -> [convertSdpIntoTsdp] Connection address retrieved in sdp: 10.235.96.150.
1438858899 -> [convertIPStrIntoTuipv] 10.235.96.150 => 10.235.96.150
1438858899 -> [methodAllowedByDistant] INFO not allowed by distant !!
1438858899 -> 1131[emitEventToMonitel] content size (lginfo): 656
1438858899 -> 1131[emitEventToMonitel] CAC = 0 eqtCAC = -1
1438858903 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858903 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858903 -> [sendLgEvtSip] Event sent on eqt : 3292 Id :-1
1438858903 -> [display_ipc_out] ------------ Begin ---------------
1438858903 -> Id : -1
1438858903 -> SUCCESSFUL
1438858903 -> xx : 0
1438858903 -> RELATIVE REQUEST : INVITE
1438858903 -> CLIR : 0
1438858903 -> COLP : 0
1438858903 -> SDP :
1438858903 -> ADDRESS : 10.235.96.150 :38082
1438858903 -> ALGOS :
1438858903 -> G729
1438858903 -> DIRECTION : SEND & RECEIVE
1438858903 -> [display_ipc_out] ------------- End ----------------
1438858903 -> [receiveSuccessfulMessage] SRV_OK received update FROM TAG on the StandBy.
1438858903 -> 1131 [CCall::getCallDuplicationData]
1438858903 -> 1131 [CCall::getCallDuplicationData] : Request URI = , Call ID = 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130, Local URI = sip:505886@10.235.96.130;user=phone, Local Tag = 41117bc11aa2b644d28b9fa5fbf8c8e6, Remote URI = sip:38982000@10.235.96.150:5061;user=phone, Remote Tag = F4ED6EF3F34A, Local CSeq = 956974466, Remote CSeq = 0
1438858903 -> [CViaSetSerializer::serialize] Serialized via set :
1438858903 -> [CRouteSet::serialize] Serialized route set : Contact=sip:38982000@10.235.96.150:5061;user=phone
1438858903 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858903 -> 1131[CMotorCall::getOutgoingCall] outgoingCall:1
1438858903 -> 1131[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
1438858903 -> 1131[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
1438858903 -> [CForkedBranch::getResponseCode] response=200.
1438858903 -> [exec_ipc] in 1744.
1438858903 -> [display_ipc_in] ------------ Begin ---------------
1438858903 -> neqt : 3292 Id : -1
1438858903 -> ACK
1438858903 -> [display_ipc_in] ------------- End ----------------
1438858903 -> [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 3292--1.
1438858903 -> [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
1438858903 -> [onIncomingEvent] ACK arrived.
1438858903 -> [receiveAckEvent] Call: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 eqt: 3292 ACCEPTED_STATE received an event.
1438858903 -> [isValidGwExt] ext gw 1 is valid
1438858903 -> 1131[CMotorCall::inviteBuildContact] Contact: sip:10.235.96.130
1438858903 -> 1131[CMotorCall::emitAckMessage] begin.
1438858903 -> 1131[CMotorCall::emitAckMessage] SDP ok.
1438858903 -> 1131 [CCall::makeGenericRequest] ACK
1438858903 -> 1131 [CCall::getDialog] Confirmed Dialog found
1438858903 -> 1576 [CDialog::createRequest]
1438858903 -> 1576 [CDialog::buildServicesForAllRequest]
1438858903 -> 1576 [CDialog::createAckRequest]
1438858903 -> 1576 [CDialog::createAckRequest], previous trans 21b7 is found
1438858903 -> 1576 [CDialog::createAckRequest], previous trans 21b7 is client
1438858903 -> 2FED [CRequest::CRequest] Creation of a request
1438858903 -> 1576 [CDialog::buildServicesForAck]
1438858903 -> 2FED [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858903 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 494)
ACK sip:38982000@10.235.96.150:5061;user=phone SIP/2.0Contact: sip:10.235.96.130User-Agent: OmniPCX Enterprise R9.1 i1.605.38To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=F4ED6EF3F34AFrom: "" <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6Call-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974466 ACKVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bK7c979ca063c19d66f7ebcfcca1ab56faMax-Forwards: 70Content-Length: 0-------------------------------------------------
1438858907 -> 21b7 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858907 -> 21b7 [CTransaction::freeTimerToken] Timer D is freed
1438858907 -> 21b7 [CTransaction::changeState] no transaction state, terminated reason : Request creation
1438858907 -> 1576 [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
1438858907 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858907 -> 1131 [CCall::getCallDuplicationData]
1438858907 -> 1131 [CCall::getCallDuplicationData] : Request URI = , Call ID = 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130, Local URI = sip:505886@10.235.96.130;user=phone, Local Tag = 41117bc11aa2b644d28b9fa5fbf8c8e6, Remote URI = sip:38982000@10.235.96.150:5061;user=phone, Remote Tag = F4ED6EF3F34A, Local CSeq = 956974466, Remote CSeq = 0
1438858907 -> [CViaSetSerializer::serialize] Serialized via set :
1438858907 -> [CRouteSet::serialize] Serialized route set : Contact=sip:38982000@10.235.96.150:5061;user=phone
1438858907 -> [exec_ipc] in end 1744.
1438858907 -> [CTransaction::notifyDialog]
1438858907 -> [CTransaction::notifyDialog] notify parent dialog
1438858907 -> 1576 [CDialog::onTransactionState(pTrans = 21b7, previousState = null, currentState = Terminated, reason = Request creation]
1438858907 -> 21B7 [~CTransaction] transaction 956974466 INVITE
1438858907 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
INVITE sip:505886@10.235.96.130 SIP/2.0Via: SIP/2.0/UDP 10.235.96.150:5061From: <sip:38982000@10.235.96.150:5061;user=phone>;tag=F4ED6EF3F34ATo: <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6Call-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974467 INVITEMax-Forwards: 70Contact: <sip:38982000@10.235.96.150:5061;user=phone>User-Agent: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Type: application/sdpContent-Length: 288v=0o=XMedius-Fax-Gateway 39566791 792 IN IP4 10.235.96.150s=absc=IN IP4 10.235.96.150t=0 0m=image 41329 udptl t38a=T38FaxVersion:0a=T38maxBitRate:14400a=T38FaxRateManagement:transferredTCFa=T38FaxMaxBuffer:8192a=T38FaxMaxDatagram:1008a=T38FaxUdpEC:t38UDPRedundancy-------------------------------------------------
1438858907 -> 2FEE [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1438858907 -> [CIOCom::receiveRequest] Received CRequest 2FEE ref=1
1438858907 -> [CIOCom::checkHostInBlackList] host=10.235.96.150
1438858907 -> [CIOCom::receiveRequest] rport1 not empty
1438858907 -> [CDispatcher::onIncomingRequest()]
1438858907 -> [CDispatcher::processRequestFromManagerIndex()] start at index 0
1438858907 -> 102 [CCallManager::onIncomingRequest()]
1438858907 -> 1131 [CCall::receiveRequest] INVITE
1438858907 -> 1131 [CCall::getDialog] Confirmed Dialog found
1438858907 -> 1576 [CDialog::receiveRequest]
1438858907 -> 1576 [CDialog::receiveInviteRequest]
1438858907 -> 1576 [CDialog::getTransactionByCSeq] CSeq = 956974467
1438858907 -> 21b8 [CTransaction::changeState] STATE CHANGED TO INITIAL
1438858907 -> 21b8 [CTransaction::changeState] notifying the parent dialog
1438858907 -> 1576 [CDialog::onTransactionState(pTrans = 21b8, previousState = Terminated, currentState = Initial, reason = None]
1438858907 -> 21b8 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
1438858907 -> 21b8 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
1438858911 -> 1576 [CDialog::onTransactionState(pTrans = 21b8, previousState = Initial, currentState = Proceeding, reason = Request reception]
1438858911 -> 21b8 [CTransProceedingState::createResponse] CResponse 2CA1 ref=1
1438858911 -> 2CA1 [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858911 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 308)
SIP/2.0 100 TryingTo: <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6From: <sip:38982000@10.235.96.150:5061;user=phone>;tag=F4ED6EF3F34ACall-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974467 INVITEVia: SIP/2.0/UDP 10.235.96.150:5061Content-Length: 0-------------------------------------------------
1438858911 -> 1576 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1438858911 -> [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
1438858911 -> [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
1438858911 -> 1576 [CDialog::addTransaction] added transaction 21b8 with branch 956974467 INVITE, with CSeq 956974467
1438858911 -> 1131 [CCall::checkAuthentication] INVITE
1438858911 -> 1131[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1438858911 -> 1131[CMotorCall::controlAuthentication] ---*--- END ---*--- Control authentication
1438858911 -> [getFromHeader].
1438858911 -> 0[CMotorCall::onReceiveRequest] route already analyzed.
1438858911 -> EAu: Block Memory Size: 82900
1438858911 -> EAu: Dupli window: 0/1 (max: 0)
1438858911 -> 21b8 [CTransConfirmedState::timerFires] Timer I fires
1438858911 -> 21b8 [CTransConfirmedState::timerFires] TimerI : Transaction changes to Terminated state
1438858911 -> 21b8 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858911 -> 21b8 [CTransaction::changeState] no transaction state, terminated reason : Timer I fires
1438858911 -> [CTransaction::notifyDialog]
1438858911 -> [CTransaction::notifyDialog] notify parent dialog
1438858911 -> 1576 [CDialog::onTransactionState(pTrans = 21b8, previousState = null, currentState = Terminated, reason = Timer I fires]
1438858911 -> 21B8 [~CTransaction] transaction 956974467 INVITE
1438858911 -> 2FEF [~CRequest] req 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974467 ACK
1438858911 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858911 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858911 -> [exec_ipc] in 1744.
1438858911 -> [display_ipc_in] ------------ Begin ---------------
1438858911 -> neqt : 3292 Id : -1
1438858911 -> BYE
1438858911 -> [display_ipc_in] ------------- End ----------------
1438858911 -> [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 3292--1.
1438858911 -> [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
1438858911 -> [onIncomingEvent] BYE arrived.
1438858911 -> [receiveByeEvent] Call: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 eqt: 3292 COMPLETED_STATE received an event.
1438858911 -> [isValidGwExt] ext gw 1 is valid
1438858911 -> 1131[CMotorCall ABCF ExtGW
1438858911 -> 1131 [CCall::makeGenericRequest] BYE
1438858911 -> 1131 [CCall::getDialog] Confirmed Dialog found
1438858911 -> 1576 [CDialog::createRequest]
1438858911 -> 1576 [CDialog::buildServicesForAllRequest]
1438858911 -> 1576 [CDialog::createByeRequest]
1438858911 -> 21b9 [CTransaction::changeState] STATE CHANGED TO INITIAL
1438858911 -> 21b9 [CTransaction::changeState] notifying the parent dialog
1438858911 -> 1576 [CDialog::onTransactionState(pTrans = 21b9, previousState = Terminated, currentState = Initial, reason = None]
1438858911 -> 2FF0 [CRequest::CRequest] Creation of a request
1438858915 -> 2FF0 [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858915 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 482)
BYE sip:38982000@10.235.96.150:5061;user=phone SIP/2.0Supported: replaces,timer,100relUser-Agent: OmniPCX Enterprise R9.1 i1.605.38To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=F4ED6EF3F34AFrom: <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6Call-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974467 BYEVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bKd0d7042135ec22b30fadc7c18fd718edMax-Forwards: 70Content-Length: 0-------------------------------------------------
1438858915 -> 21b9 [CTransInitialState::createRequest] Transaction changes to Trying state
1438858915 -> 21b9 [CTransaction::changeState] STATE CHANGED TO TRYING
1438858915 -> 21b9 [CTransaction::changeState] notifying the parent dialog
1438858915 -> 1576 [CDialog::onTransactionState(pTrans = 21b9, previousState = Initial, currentState = Trying, reason = Request creation]
1438858915 -> 21b9 [CTransTryingState::enterInState] Init timers E and F
1438858915 -> 21b9 [CTransaction::startTimer] Timer E is started (delay = 500 ms)
1438858915 -> 21b9 [CTransaction::startTimer] Timer F is started (delay = 32000 ms)
1438858915 -> 1576 [CDialog::addTransaction] added transaction 21b9 with branch z9hG4bKd0d7042135ec22b30fadc7c18fd718ed, with CSeq 956974467
1438858915 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1438858915 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858915 -> [exec_ipc] in end 1744.
1438858915 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
SIP/2.0 200 OKVia: SIP/2.0/UDP 10.235.96.130;branch=z9hG4bKd0d7042135ec22b30fadc7c18fd718edFrom: <sip:505886@10.235.96.130;user=phone>;tag=41117bc11aa2b644d28b9fa5fbf8c8e6To: <sip:38982000@10.235.96.150:5061;user=phone>;tag=F4ED6EF3F34ACall-ID: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130CSeq: 956974467 BYEAllow: INVITE, ACK, BYE, CANCELContact: <sip:38982000@10.235.96.150:5061;user=phone>Server: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Length: 0-------------------------------------------------
1438858915 -> [CIOCom::receiveResponse] CResponse 2CA3 ref=1
1438858915 -> [CDispatcher::onIncomingResponse]
1438858915 -> [CDispatcher::processResponseFromManagerIndex] start at index 0
1438858915 -> 102 [CCallManager::onIncomingResponse]
1438858915 -> 1131 [CCall::receiveResponse] 200
1438858915 -> 1131 [CCall::receiveResponse]Trying to find the right dialog
1438858915 -> 1131 [CCall::getDialog] Confirmed Dialog found
1438858915 -> 1131 [CCall::receiveResponse]One dialog found
1438858915 -> 1576 [CDialog::receiveResponse]
1438858915 -> 21b9 [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
1438858915 -> 21b9 [CTransaction::changeState] STATE CHANGED TO COMPLETED
1438858915 -> 1576 [CDialog::onTransactionState(pTrans = 21b9, previousState = Trying, currentState = Completed, reason = Final resp reception]
1438858915 -> 21b9 [CTransaction::freeTimerToken] Timer E is freed
1438858915 -> 21b9 [CTransaction::freeTimerToken] Timer F is freed
1438858915 -> 21b9 [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
1438858915 -> 1131[CMotorCall::onReceiveResponse] Update2 the Other context.
1438858915 -> [receiveSuccessfulMessage] Call: 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 eqt: 3292 TERMINATED_STATE received a message.
1438858915 -> 1131[emitEventToMonitel] content size (lginfo): 656
1438858919 -> 1131[emitEventToMonitel] CAC = 0 eqtCAC = -1
1438858919 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858919 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858919 -> [sendLgEvtSip] Event sent on eqt : 3292 Id :-1
1438858919 -> [display_ipc_out] ------------ Begin ---------------
1438858919 -> Id : -1
1438858919 -> SUCCESSFUL
1438858919 -> xx : 0
1438858919 -> RELATIVE REQUEST : BYE
1438858919 -> CLIR : 0
1438858919 -> COLP : 0
1438858919 -> [display_ipc_out] ------------- End ----------------
1438858919 -> [exec_ipc] in 1744.
1438858919 -> [display_ipc_in] ------------ Begin ---------------
1438858919 -> neqt : 3292 Id : -1
1438858919 -> SIP EQT RELEASED
1438858919 -> [display_ipc_in] ------------- End ----------------
1438858919 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 3292--1.
1438858919 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 3292 has released its equipment.
1438858919 -> 1131[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1438858919 -> 1131[emitEventToMonitel] content size (lginfo): 656
1438858919 -> SIP_EQT_RELEASE_ACK
1438858919 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1438858919 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858919 -> 1131[CMotorCall::unRegister] Remove eqt : 3292 diag : -1 from the map.
1438858919 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 3292 erased.
1438858919 -> [CMotorCallManager::onIncomingEvent] killSession.
1438858919 -> 1131 [CCall::killSession]
1438858919 -> 21b6 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858919 -> 21b6 [CTransaction::changeState] no transaction state, terminated reason : None
1438858919 -> 21b9 [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858919 -> 21b9 [CTransaction::freeTimerToken] Timer K is freed
1438858919 -> 21b9 [CTransaction::changeState] no transaction state, terminated reason : None
1438858919 -> 1131 [CCall::onKill Session Call manager close is called]
1438858919 -> 1131 [CCall::killSession] notifying the call manager
1438858919 -> 102 [CCallManager::onCallClosed]
1438858919 -> 102 [CCallManager::onCallClosed()] Call 1131 closed. Removing call 216470632 from the maps
1438858919 -> [CMotorCallManager::onNotifyCallClosed] Call : 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 is closed.
1438858919 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1438858919 -> [CCall::onKill] set callmanager to null
1438858919 -> [exec_ipc] in end 1744.
1438858919 -> [CTransaction::notifyDialog]
1438858919 -> [CTransaction::notifyDialog] notify parent dialog
1438858919 -> 1575 [CDialog::onTransactionState(pTrans = 21b6, previousState = null, currentState = Terminated, reason = None]
1438858919 -> 1575 [CDialog::onTransactionState] dialog is terminated
1438858919 -> 1575 [CDialog::onTransactionState] onDialogClosed
1438858919 -> 1131 [CCall::onDialogClosed]
1438858919 -> 1131 [CCall::onDialogClosed] not only initial *********
1438858919 -> 1131 [CCall::onDialogClosed]: the dialog 1576 is NOT closed
1438858919 -> 21B6 [~CTransaction] transaction 956974466 INVITE
1438858919 -> 2C9F [~CResponse] resp(100) 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974466 INVITE
1438858923 -> [CTransaction::notifyDialog] notify parent dialog
1438858923 -> 1576 [CDialog::onTransactionState(pTrans = 21b9, previousState = null, currentState = Terminated, reason = None]
1438858923 -> 1131 [CCall::onDialogClosed]
1438858923 -> 1131 [CCall::onDialogClosed] not only initial *********
1438858923 -> 1131 [CCall::onDialogClosed]: the dialog 1576 is closed
1438858923 -> 1131 [CCall::onDialogClosed] All the dialogs in the Call are closed
1438858923 -> 21B9 [~CTransaction] transaction 956974467 BYE
1438858923 -> 2CA3 [~CResponse] resp(200) 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974467 BYE
1438858923 -> 102 [CCallManager::removeGarbage] at index i = 0
1438858923 -> 1131[CMotorCall::~CMotorCall] Call : 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 is being destructed.
1438858923 -> 1131 [CCall::~CCall]
1438858923 -> 1131 [CCall::removeGarbage]
1438858923 -> 1576 [CDialog::~CDialog]
1438858923 -> 1576 [~CDialog] delete ack request # 0
1438858923 -> 2FED [~CRequest] req 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974466 ACK
1438858923 -> 2CA0 [~CResponse] resp(200) 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974466 INVITE
1438858923 -> 1575 [CDialog::~CDialog]
1438858923 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1438858923 -> 2FEC [~CRequest] req 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974466 INVITE
1438858923 -> 2FF0 [~CRequest] req 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974467 BYE
1438858923 -> 2CA2 [~CResponse] resp(200) 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974467 INVITE
1438858923 -> 2FEE [~CRequest] req 3b3e45a6ede1e9108f1308f8bc69b1c1@10.235.96.130 956974467 INVITE
1438858923 -> EAu: Block Memory Size: 82900
1438858923 -> EAu: Dupli window: 0/1 (max: 0)
1438858923 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858923 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858923 -> [exec_ipc] in 1744.
1438858923 -> [display_ipc_in] ------------ Begin ---------------
1438858923 -> neqt : 3292 Id : -1
1438858923 -> INVITE
1438858923 -> REQUEST URI : <> 38982000@10.235.96.150:5061 ; user=phone
1438858923 -> FROM : <> 505886@10.235.96.130:5060 ; user=phone
1438858923 -> TO : <> 38982000@10.235.96.150:5061 ; user=phone
1438858923 -> CAC : 0
1438858923 -> neqt CAC : -1
1438858923 -> CLIR : 0
1438858923 -> SDP :
1438858923 -> ADDRESS : 10.235.96.147 :32148
1438858923 -> ALGOS :
1438858923 -> G729
1438858923 -> G723
1438858923 -> PCMA
1438858923 -> 97
1438858923 -> DIRECTION : SEND & RECEIVE
1438858923 -> N_GW_EXT : 1
1438858923 -> [display_ipc_in] ------------- End ----------------
1438858923 -> [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 3292--1.
1438858923 -> [CMotorCallManager::onIncomingEvent] New Call created.
1438858923 -> [CMotorCallManager::callFactory].
1438858923 -> [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R9.1 i1.605.38
1438858923 -> [CMotorCallManager::callFactory]=ce74fd8.
1438858923 -> [CMotorCallManager::onIncomingEvent] eqt=3292 -1.
1438858923 -> [CMotorCallManager::insertCallwithEqt] CMotorCall 3292 inserted.
1438858923 -> [quoteString] => ""
1438858923 -> 1132[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
1438858923 -> 1132[CMotorCall::setFilterUsedMode] To be traced = 0
1438858923 -> [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
1438858923 -> [onIncomingEvent] INVITE arrived.
1438858923 -> [receiveInviteEvent] Call: eqt: 3292 INITIAL_STATE received an event.
1438858923 -> 1132[CMotorCall::emitInviteMessage] begin.
1438858923 -> [isValidGwExt] ext gw 1 is valid
1438858923 -> 1132[CMotorCall::inviteBuildAurlWithBelongingDomain] extGw=1
1438858927 -> [quoteString] => ""
1438858927 -> [is_addr_in_dico] user=38982000 host=10.235.96.150
1438858927 -> [isUserDeclared] 38982000@10.235.96.150
1438858927 -> [isUserDeclared] found in the dictionnary.
1438858927 -> [is_addr_in_dico] other sip user
1438858927 -> 1132[CMotorCall::inviteBuildAurlWithoutBelongingDomain] P-Asserted-Identity: "" <sip:505886@10.235.96.130;user=phone>
1438858927 -> 1132[CMotorCall::emitInviteMessage] From: "" <sip:505886@10.235.96.130;user=phone>
1438858927 -> 1132[CMotorCall::emitInviteMessage] reqUri :sip:38982000@10.235.96.150:5061;user=phone
1438858927 -> 1132[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1
1438858927 -> [isValidGwExt] ext gw 1 is valid
1438858927 -> 1132[CMotorCall ABCF ExtGW
1438858927 -> 1132[CMotorCall::inviteBuildSupportedHeader] Invite directed to external gw : 1
1438858927 -> 1132[CMotorCall::emitInviteMessage] Request Uri : sip:38982000@10.235.96.150:5061;user=phone
1438858927 -> 1132[CMotorCall::emitInviteMessage] To: <sip:38982000@10.235.96.150:5061;user=phone>
1438858927 -> am_I_PCS SCSWorking : NO
1438858927 -> check_PCSstate
1438858927 -> check_PCSstate stat of PCS is : -1
1438858927 -> 1132[CMotorCall::inviteBuildContact] begin. crms00137339
1438858927 -> [137339 - inviteBuildContact] trunk_number=1799 extGw =1.
1438858927 -> [137339-InviteBuildContact] userinfo : 505886
1438858927 -> 1132[CMotorCall::inviteBuildContact] Contact: sip:505886@10.235.96.130
1438858927 -> 1132[CMotorCall::emitInviteMessage] uacGatewayMode=1 uacRefresher=1.
1438858927 -> 1132[CMotorCall::makeRequestSdp] Begin sdp.
1438858927 -> 1132[CMotorCall::makeRequestSdp] Direction: 0.
1438858927 -> 1132[CMotorCall::makeRequestSdp] format 97
1438858927 -> 1132[CMotorCall::makeRequestSdp] Final sdp.
1438858927 -> 1132[CMotorCall::emitInviteMessage] The sdp build.
1438858927 -> 1132[CMotorCall::new_determineTargetsForTheRequest] is not Responsible For This URI.
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] isResolution=0.
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] target is not the local node.
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] nb contacts=1.
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 38982000
1438858927 -> [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest]-->extGw=1
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] contact : sip:38982000@10.235.96.150:5061;user=phone
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] nb available licenses=14 .
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest]-->pSipAddSpec->getHost()=10.235.96.150
1438858927 -> 1132[CMotorCall::makeInitialMotorRequest] user= 38982000
1438858927 -> [CGWMngData::isMainServer] CPU is MAIN.
1438858927 -> [CGWMngData::isMainServer] checkwith PCS = 0
1438858927 -> [CMotorCall::makeInitialMotorRequest] count = 3.
1438858927 -> [CMotorCall::makeInitialMotorRequest] service=0 0xbffff0b8.
1438858927 -> [CMotorCall::makeInitialMotorRequest] service=1 0xbfffed58.
1438858927 -> [CMotorCall::makeInitialMotorRequest] service=2 0xbfffe73c.
1438858927 -> 1132 [CCall::makeGenericRequest] INVITE
1438858927 -> 21bc [CTransConfirmedState::timerFires] Timer I fires
1438858931 -> 21bc [CTransConfirmedState::timerFires] TimerI : Transaction changes to Terminated state
1438858931 -> 21bc [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858931 -> 21bc [CTransaction::changeState] no transaction state, terminated reason : Timer I fires
1438858931 -> [CTransaction::notifyDialog]
1438858931 -> [CTransaction::notifyDialog] notify parent dialog
1438858931 -> 1578 [CDialog::onTransactionState(pTrans = 21bc, previousState = null, currentState = Terminated, reason = Timer I fires]
1438858931 -> 21BC [~CTransaction] transaction 448107240 INVITE
1438858931 -> 2FF4 [~CRequest] req 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107240 ACK
1438858931 -> EAu: Block Memory Size: 82900
1438858931 -> EAu: Dupli window: 0/1 (max: 0)
1438858931 -> main.trace.timer = 480mn
1438858933 -> EAu: Block Memory Size: 82900
1438858933 -> EAu: Dupli window: 0/1 (max: 0)
1438858948 -> EAu: Block Memory Size: 82900
1438858948 -> EAu: Dupli window: 0/1 (max: 0)
1438858963 -> EAu: Block Memory Size: 82900
1438858963 -> EAu: Dupli window: 0/1 (max: 0)
1438858972 -> cl_daCalendar::dayOfWeek
1438858972 -> cl_daCalendar::dayType
1438858972 -> nbDays = 5
1438858972 -> clock=18748800 (1970/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858972 -> clock=18748800 (1970/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858972 -> clock=1438815600 (2015/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858972 -> clock=1438815600 (2015/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858972 -> clock=1438815600 (2015/08/06), nwd[4].time=1106175600 (2005/01/20) [min=4, max=4]
1438858978 -> EAu: Block Memory Size: 82900
1438858978 -> EAu: Dupli window: 0/1 (max: 0)
1438858978 -> main.trace.timer = 480mn
1438858982 -> cl_daCalendar::dayOfWeek
1438858982 -> cl_daCalendar::dayType
1438858982 -> nbDays = 5
1438858982 -> clock=18748800 (1970/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858982 -> clock=18748800 (1970/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858982 -> clock=1438815600 (2015/08/06), nwd[2].time=15984000 (1970/07/05) [min=0, max=4]
1438858982 -> clock=1438815600 (2015/08/06), nwd[3].time=26265600 (1970/11/01) [min=3, max=4]
1438858982 -> clock=1438815600 (2015/08/06), nwd[4].time=1106175600 (2005/01/20) [min=4, max=4]
1438858984 -> RECEIVE MESSAGE FROM NETWORK (10.235.96.150:5061 [UDP])
BYE sip:10.235.96.130 SIP/2.0Via: SIP/2.0/UDP 10.235.96.150:5061From: sip:38982000@10.235.96.150:5061;tag=C0EF1E5F2193To: sip:505886@10.235.96.130:5060;tag=a23c791fae3a55d0fa23d75c287b31f7Call-ID: 961dae2198ad2235329edfc77cff8a26@10.235.96.130CSeq: 448107241 BYEMax-Forwards: 70Contact: <sip:38982000@10.235.96.130:5060;user=phone>User-Agent: Alcatel-Lucent OmniTouch Fax Server Application/6.5.6.26Content-Length: 0-------------------------------------------------
1438858984 -> 2FF5 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1438858984 -> [CIOCom::receiveRequest] Received CRequest 2FF5 ref=1
1438858984 -> [CIOCom::checkHostInBlackList] host=10.235.96.150
1438858984 -> [CIOCom::receiveRequest] rport1 not empty
1438858984 -> [CDispatcher::onIncomingRequest()]
1438858984 -> [CDispatcher::processRequestFromManagerIndex()] start at index 0
1438858984 -> 102 [CCallManager::onIncomingRequest()]
1438858984 -> 1132 [CCall::receiveRequest] BYE
1438858984 -> 1132 [CCall::getDialog] Confirmed Dialog found
1438858984 -> 1578 [CDialog::receiveRequest]
1438858984 -> 1578 [CDialog::receiveBasicRequest]
1438858984 -> 21bd [CTransaction::changeState] STATE CHANGED TO INITIAL
1438858984 -> 21bd [CTransaction::changeState] notifying the parent dialog
1438858984 -> 1578 [CDialog::onTransactionState(pTrans = 21bd, previousState = Terminated, currentState = Initial, reason = None]
1438858984 -> 21bd [CTransInitialState::receiveRequest] Transaction changes to Trying state
1438858984 -> 21bd [CTransaction::changeState] STATE CHANGED TO TRYING
1438858984 -> 1578 [CDialog::onTransactionState(pTrans = 21bd, previousState = Initial, currentState = Trying, reason = Request reception]
1438858984 -> 1578 [CDialog::addTransaction] added transaction 21bd with branch 448107241 BYE, with CSeq 448107241
1438858984 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1438858984 -> 1132 [CCall::checkAuthentication] BYE
1438858984 -> 1132[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1438858984 -> 1132[CMotorCall::controlAuthentication] ---*--- END ---*--- Control authentication
1438858984 -> 0[CMotorCall::onReceiveRequest] route already analyzed.
1438858984 -> 1132[CMotorCall::onReceiveRequest] request for gateway.
1438858984 -> 1132[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
1438858984 -> [receiveByeMessage] Call: 961dae2198ad2235329edfc77cff8a26@10.235.96.130 eqt: 3292 COMPLETED_STATE received a message.
1438858984 -> 1132[emitEventToMonitel] content size (lginfo): 656
1438858984 -> 1132[emitEventToMonitel] CAC = 0 eqtCAC = -1
1438858984 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858984 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858984 -> [sendLgEvtSip] Event sent on eqt : 3292 Id :-1
1438858984 -> [display_ipc_out] ------------ Begin ---------------
1438858984 -> Id : -1
1438858984 -> BYE
1438858984 -> [display_ipc_out] ------------- End ----------------
1438858984 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858984 -> [exec_ipc] in 1744.
1438858984 -> [display_ipc_in] ------------ Begin ---------------
1438858984 -> neqt : 3292 Id : -1
1438858984 -> SUCCESSFUL
1438858984 -> xx : 0
1438858984 -> RELATIVE REQUEST : BYE
1438858984 -> CLIR : 0
1438858984 -> COLP : 0
1438858984 -> [display_ipc_in] ------------- End ----------------
1438858984 -> [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 3292--1.
1438858984 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1438858984 -> [onIncomingEvent] SUCCESSFUL arrived.
1438858984 -> [onIncomingEvent] relative_request = 10755
1438858984 -> [receiveSuccessfulEvent] Call: 961dae2198ad2235329edfc77cff8a26@10.235.96.130 eqt: 3292 TERMINATED_STATE received an event.
1438858988 -> [isValidGwExt] ext gw 1 is valid
1438858988 -> 1132[CMotorCall ABCF ExtGW
1438858988 -> 1132[CMotorCall::inviteBuildContact] Contact: sip:10.235.96.130
1438858988 -> 1132 [CCall::findFirstServerTrans]
1438858988 -> 1578 [CCall::findFirstServerTrans]
1438858988 -> 1578 [CCallLeg::findFirstOpenServerTrans] Current Request in transactionMapByBranch
1438858988 -> 1132 [CCall::makeGenericResponse] 200
1438858988 -> 1132 [CCall::getDialog] Confirmed Dialog found
1438858988 -> 1578 [CDialog::createResponse] 200
1438858988 -> 21bd [CTransTryingState::createResponse] CResponse 2CA8 ref=1
1438858988 -> 2CA8 [CMessage::send] sip_sendMessage (10.235.96.150:5061)
1438858988 -> SEND MESSAGE TO NETWORK (10.235.96.150:5061 [UDP]) (BUFF LEN = 444)
SIP/2.0 200 OKAllow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATESupported: replaces,timer,100relUser-Agent: OmniPCX Enterprise R9.1 i1.605.38To: sip:505886@10.235.96.130:5060;tag=a23c791fae3a55d0fa23d75c287b31f7From: sip:38982000@10.235.96.150:5061;tag=C0EF1E5F2193Call-ID: 961dae2198ad2235329edfc77cff8a26@10.235.96.130CSeq: 448107241 BYEVia: SIP/2.0/UDP 10.235.96.150:5061Content-Length: 0-------------------------------------------------
1438858988 -> 21bd [CTransTryingState::createResponse] Final : Transaction changes to Completed state
1438858988 -> 21bd [CTransaction::changeState] STATE CHANGED TO COMPLETED
1438858988 -> 21bd [CTransaction::changeState] notifying the parent dialog
1438858988 -> 1578 [CDialog::onTransactionState(pTrans = 21bd, previousState = Trying, currentState = Completed, reason = Final resp creation]
1438858988 -> 21bd [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
1438858988 -> 1578 [CDialog::updateRouteSet] there are 0 record-route headers
1438858988 -> 2CA7 [~CResponse] resp(200) 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107240 INVITE
1438858988 -> 2FF3 [~CRequest] req 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107240 INVITE
1438858988 -> [exec_ipc] in end 1744.
1438858988 -> [ipc_thread] IPC Thread : Ipc reception 1745.
1438858988 -> [ipc_thread] IPC Thread : TCL thread signaled.
1438858988 -> [exec_ipc] in 1744.
1438858988 -> [display_ipc_in] ------------ Begin ---------------
1438858988 -> neqt : 3292 Id : -1
1438858988 -> SIP EQT RELEASED
1438858988 -> [display_ipc_in] ------------- End ----------------
1438858988 -> [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 3292--1.
1438858988 -> [CMotorCallManager::onIncomingEvent] The call with eqt: 3292 has released its equipment.
1438858988 -> 1132[CMotorCall::emitSipEqtReleaseAck] SIP_EQT_RELEASE_ACK
1438858988 -> 1132[emitEventToMonitel] content size (lginfo): 656
1438858988 -> 1132[emitEventToMonitel] CAC = 0 eqtCAC = -1
1438858988 -> [sendLgEvtSip] Event sent on eqt : 3292 Id :-1
1438858988 -> [display_ipc_out] ------------ Begin ---------------
1438858988 -> Id : -1
1438858988 -> SIP_EQT_RELEASE_ACK
1438858988 -> [display_ipc_out] ------------- End ----------------
1438858988 -> [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
1438858988 -> SendToSipgwCpuSec: Message sent to the STAND-BY CPU
1438858988 -> 1132[CMotorCall::unRegister] Remove eqt : 3292 diag : -1 from the map.
1438858988 -> [CMotorCallManager::eraseCallwithEqt] CMotorCall 3292 erased.
1438858988 -> [CMotorCallManager::onIncomingEvent] killSession.
1438858988 -> 1132 [CCall::killSession]
1438858992 -> 21ba [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858992 -> 21ba [CTransaction::changeState] no transaction state, terminated reason : None
1438858992 -> 21bd [CTransaction::changeState] STATE CHANGED TO TERMINATED
1438858992 -> 21bd [CTransaction::freeTimerToken] Timer J is freed
1438858992 -> 21bd [CTransaction::changeState] no transaction state, terminated reason : None
1438858992 -> 1132 [CCall::onKill Session Call manager close is called]
1438858992 -> 1132 [CCall::killSession] notifying the call manager
1438858992 -> 102 [CCallManager::onCallClosed]
1438858992 -> 102 [CCallManager::onCallClosed()] Call 1132 closed. Removing call 216485848 from the maps
1438858992 -> [CMotorCallManager::onNotifyCallClosed] Call : 961dae2198ad2235329edfc77cff8a26@10.235.96.130 is closed.
1438858992 -> [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1438858992 -> [CCall::onKill] set callmanager to null
1438858992 -> [exec_ipc] in end 1744.
1438858992 -> [CTransaction::notifyDialog]
1438858992 -> [CTransaction::notifyDialog] notify parent dialog
1438858992 -> 1577 [CDialog::onTransactionState(pTrans = 21ba, previousState = null, currentState = Terminated, reason = None]
1438858992 -> 1577 [CDialog::onTransactionState] dialog is terminated
1438858992 -> 1577 [CDialog::onTransactionState] onDialogClosed
1438858992 -> 1132 [CCall::onDialogClosed]
1438858992 -> 1132 [CCall::onDialogClosed] not only initial *********
1438858992 -> 1132 [CCall::onDialogClosed]: the dialog 1578 is NOT closed
1438858992 -> 21BA [~CTransaction] transaction 448107239 INVITE
1438858992 -> 2CA4 [~CResponse] resp(100) 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107239 INVITE
1438858992 -> 1578 [CDialog::onTransactionState(pTrans = 21bd, previousState = null, currentState = Terminated, reason = None]
1438858992 -> 1132 [CCall::onDialogClosed]: the dialog 1578 is closed
1438858992 -> 1132 [CCall::onDialogClosed] All the dialogs in the Call are closed
1438858992 -> 21BD [~CTransaction] transaction 448107241 BYE
1438858992 -> 102 [CCallManager::removeGarbage] at index i = 0
1438858992 -> 1132[CMotorCall::~CMotorCall] Call : 961dae2198ad2235329edfc77cff8a26@10.235.96.130 is being destructed.
1438858992 -> 1132 [CCall::~CCall]
1438858992 -> 1132 [CCall::removeGarbage]
1438858992 -> 1578 [CDialog::~CDialog]
1438858992 -> 1578 [~CDialog] delete ack request # 0
1438858992 -> 1577 [CDialog::~CDialog]
1438858992 -> [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
1438858992 -> 2FF2 [~CRequest] req 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107239 ACK
1438858992 -> 2CA5 [~CResponse] resp(200) 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107239 INVITE
1438858992 -> 2FF1 [~CRequest] req 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107239 INVITE
1438858992 -> 2CA8 [~CResponse] resp(200) 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107241 BYE
1438858992 -> 2FF5 [~CRequest] req 961dae2198ad2235329edfc77cff8a26@10.235.96.130 448107241 BYE
1438858993 -> EAu: Block Memory Size: 82900
1438858993 -> EAu: Dupli window: 0/1 (max: 0)
(1)pst_cpu6> exit
l
Alcatel-Lucent OmniPCX Enterprise
pst_cpu6 login:
Return to “SIP”
