[ASK] VPRN Interface down due bind VPLS service
thekotaksampah
Post by thekotaksampah »
Hi fellas,
Have you ever meet this kind of issue:
A:SITE-ALU-B>config>service>vprn>if# /show router 2002 interface shunt-to-A detail
Interface Table (Service: 2002)
Interface
If Name : shunt-to-A
Admin State : Up Oper (v4/v6) : Down/Down
Down Reason Code : assocObjNotReady
Protocols : None
IP Addr/mask : 192.168.130.2/30 Address Type : Primary
IGP Inhibit : Disabled Broadcast Address : Host-ones
HoldUp-Time : 0 Track Srrp Inst : 0
Details
I try to make vprn interface and bind it to vpls service. But interface looks down. I try to shut no shut interface, but it can't solve the issue.
I looking for assocObjNotReady, what does it mean?
Any Idea?
Technical Blog: ngoprek.achyarnurandi.id
paramount
Re: [ASK] VPRN Interface down due bind VPLS service
Post by paramount »
Hi, can you post the configs for both VPRN and vpls services and also confirm card types.
Cheers
Sent from my C6833 using Tapatalk
mivens
Post by mivens »
One reason can be the SDP associated with your service is down.
For example:
    service
        vprn 21099 customer 18 create
            interface "ixia-test-rvpls" create
                address 192.168.251.1/29
                spoke-sdp 990:990 create
                   shutdown
                exit
            exit
7750 # show router 21099 interface "ixia-test-rvpls" detail  | match "Down Reason Code"
7750# configure service vprn 21099 interface "ixia-test-rvpls" spoke-sdp  990:990 no shutdown
7750# show router 21099 interface "ixia-test-rvpls" detail  | match "Down Reason Code"
7750#
Stoffen
Post by Stoffen »
You need to configure route-destinguisher in the VPRN.
I would also recommend to verify the mtu between the services:
show router ldp bindings active service 21099 detail
Look at LMTU and RMTU. They need to match. Change in vprn with "ip-mtu" on interface to match VPLS MTU.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
thekotaksampah
Thank guys,
I miss to activate the vc-id, this issue is solved.
when interface bind to vpls service, reason also triggered when miss put command " allow-ip-int-binding " in vpls.
So I can make conclude why interface vprn :
1. vc-id is in admin shutdown state
2. miss allow-ip-int-binding command if using rvpls
3. missing put rd in command.
Stoffen
Post by Stoffen »
thekotaksampah wrote: 1. vc-id is in admin shutdown state
Cannot belive I missed that one :)
That would surely be a showstopper :)
[flash=]
Christoffer
Nokia SRA #265
LinkedIN
[/flash]
Return to “7750 SR”
