Does anyone know this decision in the daily work ?.
I have assumed that it is because it has oxo this system, but it should not take that decision I think.
A greeting
error 8770 in work daily Version 2.5
JoseFaura
Re: error 8770 in work daily Version 2.5
SEE ALARMS log and try to do an immediat nmc restart
JoseFaura
I rebooted and the NMC and the server process, but is giving the same error.
In the alarms gives no details of the failure.
Thank you
Thank you
JoseFaura
Any new idea?
Failure continues in the same process and the rest is done well.
Thank you
Thank you
Zero
Hi JoseFaura,
I'm not certain yet on this but you may try checking the installed Java --should not be updated or a different version from the installation. I've noticed some syntax error indicated on your attached screen capture.
Thanks,
Zero
Thanks,
Zero
