Question by memory in 7450
dds
Post by dds »
Hello! Sorry for my Inglish language.
Please help me. Im not find information about memory instaled to 7450 ess. We need use 7450 ess to BGP router for 2 provider with full view.
Question: How many memory installed in to 7450 ess? Will there be enough memory for receiving the 2 tables full view?
PS: I find information that 7450 ess-1 and 7750 SR-1 has the same hardware. Confuses that one - switch, and the other - router.
Thank you! Alex.
thekotaksampah
Re: Question by memory in 7450
Post by thekotaksampah »
Hi dds,
have you try do command
show system memory-pools
so you can find like this
*A:7450-ESS7# show system memory-pools
Memory Pools
Name               Max Allowed    Current Size      Max So Far          In Use
BFD                   No limit      11,465,920      11,465,920      10,669,320
BGP                   No limit       3,145,728       3,145,728       2,194,648
CFLOWD                No limit       1,048,576       1,048,576          50,112
Cards & Ports         No limit      99,909,344      99,909,344      97,775,744
DHCP Server           No limit       1,048,576       1,048,576         208,824
ICC                  8,388,608       2,097,152       2,097,152       1,870,160
IGMP/MLD              No limit       1,048,576       1,048,576         467,336
IOM                   No limit       2,097,152       2,097,152          82,456
IP Stack              No limit      33,080,592      37,274,896      26,423,632
IS-IS                 No limit       1,048,576       1,048,576         581,384
ISA                   No limit       1,572,864       1,572,864          79,552
LDP                   No limit      23,068,672      25,165,824      22,059,888
Logging             92,274,688       7,340,032       9,437,184       5,893,032
MPLS/RSVP             No limit      13,988,648      15,037,224      13,448,856
MSDP                  No limit               0               0               0
Management            No limit      10,223,648     101,038,560       9,136,544
OAM                   No limit       1,048,576       3,145,728         376,224
OSPF                  No limit      39,190,592      39,190,592      37,077,200
PIM                   No limit       2,097,152       2,097,152       1,037,704
RIP                   No limit               0               0               0
RTM/Policies          No limit       9,699,392       9,699,392       8,353,176
Redundancy            No limit      22,020,096      22,020,096         853,776
Services              No limit      10,149,000      11,197,576       9,391,720
Stats                 No limit       1,048,576       1,048,576          95,632
Subscriber Mgmt       No limit       3,670,016       3,670,016         531,760
System                No limit      45,246,480      47,776,392      40,963,888
VRRP                  No limit       1,048,576       1,048,576          82,656
WEB Redirect         8,388,608       2,097,152       2,097,152       1,378,664
Current Total Size :    349,499,664 bytes
Total In Use       :    291,083,888 bytes
Available Memory   :  2,053,226,160 bytes
*A:7450-ESS7#
Technical Blog: ngoprek.achyarnurandi.id
Return to “7450 ESS”
