can't config 4135 with oxo
pankrawat
Post by pankrawat »
hello all
I am trying to configure 4135 with oxo in static mode with vlan enable.
on phone its showing sip stack error.
on logs "switch registrar to ip of pbx"
"using not registered account"
Please help me on this
pankaj
enio.eltz
Re: can't config 4135 with oxo
Post by enio.eltz »
Any trace? What is its configuration (IP@, SIP port)?
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
pankrawat
Post by pankrawat »
thanks for reply
i manage to resister 4135 with oxo but now when try to call any number an error occur that is "internal server error".
Any suggestion?
pankaj
pankrawat
Post by pankrawat »
sip trace
ep 2 13:58:07: RX 363 bytes Response msg 100/INVITE/cseq=16182 (rdata0x1df6ec) from UDP 192.168.0.11:5059:
SIP/2.0 100 trying -- your call is important to us
Via: SIP/2.0/UDP 192.168.0.18:5060;rport=5060;branch=z9hG4bKPjSTld4OZvyCxNpa5bTAPc0-.hWqSsKlxT
From: <sip:303@192.168.0.11>;tag=B82oCTITICscFkGGAcNWefxC8TznpS1v
To: <sip:0@192.168.0.11>
Call-ID: SC7pOoBScgxgWRB-DMSAMjk1HZFfQ9jM
CSeq: 16182 INVITE
Server: kamailio (3.2.2 (ppc/linux))
Content-Length: 0
Sep 2 13:58:07: RX 331 bytes Response msg 100/INVITE/cseq=16182 (rdata0x1df6ec) from UDP 192.168.0.11:5059:
SIP/2.0 100 Trying
CSeq: 16182 INVITE
Content-Length: 0
Sep 2 13:58:07: RX 450 bytes Response msg 500/INVITE/cseq=16182 (rdata0x1df6ec) from UDP 192.168.0.11:5059:
SIP/2.0 500 Internal Server Error
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE
User-Agent: OxO_SPG_910/040.001
To: <sip:0@192.168.0.11>;tag=bb6f87375b33489ef0269aea0a4f7f77
CSeq: 16182 INVITE
Content-Length: 0
Sep 2 13:58:07: TX 416 bytes Request msg ACK/cseq=16182 (tdta0x2058a0) to UDP 192.168.0.11:5059:
ACK sip:0@192.168.0.11;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.0.18:5060;rport;branch=z9hG4bKPjSTld4OZvyCxNpa5bTAPc0-.hWqSsKlxT
Max-Forwards: 70
CSeq: 16182 ACK
Route: <sip:192.168.0.11:5059;transport=udp;lr>
Content-Length: 0
enio.eltz
Post by enio.eltz »
You are using SIP port 5060. OXO doesn't listen to that port on extensions. You must configure port 5059.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
pankrawat
Post by pankrawat »
thanks
but how to configure it?
plz give some steps.
enio.eltz
Post by enio.eltz »
I have never configured 4135 but usually when we need to set up the port we configure on the device the IP_OXO:5059
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
pankrawat
Post by pankrawat »
plz check image attached
that way i have to define
also what's 0 ?
yes see oxo replied to you via 5059
signaling path should be at port 5059
Return to “SIP Extension”
