A law to Mu law conversion
beirut
Post by beirut »
Is it possible configuring a shelf with GD Media gateway and ISDN T2 A Law , connected to an OXE 11.0.1 Appliance server configured for mu law in the US?
Same question, using SIP trunk with A law, connected to OXE in Mu law
I know from release 11, it has been added a feature.
Will the OXE do the law conversion with carriers?
Split
Re: A law to Mu law conversion
Post by Split »
Before R11 you must use 2 oxe and connect them with a abc-f link in R11 ist possilbe to use 2 Media Gateway one with a-law and the other with mu-Law ....but i am not sure if already R11.0 or R11.1
alaint73
Post by alaint73 »
just as a follow up to this,
I have a customer with node in Europe ( using A-Law) and would like to have a brand new OXE in US ( Seattle) that would be interconnected with Europe via ABC-F IP Trunk.
ABCF-IP is managed between US and the European Node as seeing below.
Eg: Node1(us)--------ABC-F IP Trunk-------Node2(France)
On US Node ( which will be utilizing Mu-Law) should i need to have a dedicated Shelf ( with dedicated GD-3) that would be handling A-law to mu-law conversion and vice versa ?
Because calls coming from Europe Node across the ABC-F IP Trunk will arrive in US on the Node in A-Law G711, and it needs to be converted on my US node in Mu-Law.
Thus my initial incline was to have a separated Common-Hardware Shelf with GD-3 that would only be terminating the ABC-F2 IP trunk and handling conversion back and forth.
but someone from ALE tech support told me that such dedicated Rack is not needed, and that it would automatically detect A-Law and convert in Mu-Law.
is that accurate? please your input would be very much appreciated.
No. Support already answered your question. You can also check the topic in the system documentation.
Return to “System”
