Hi guys,
Does anyone have a discription on the different options/settings for the Telephone Facility Category?
We want to compare the settings but I can't find an adequate description in the system docs.
Example:
Local Services\Automatic Answering
External Services\Direct trunk seizure
External Services\Priority of Call
Suffixes\Ringback on free or busy set
thx
Phone Facility Category
L_lefante
Re: Phone Facility Category
Some of them have a description if you press ctrl+i (or tab key) from mgr.
For me - not good idea to check all item in phone feature COS.
1) When I want to use new COS for some reason - I'm just copy used COS value to new COS and change only interested items.
2) When I want to implement some feature (f.e. call forwarding) - I'm read in system doc/ user services - chapter about forwarding/overflow. In doc written what we need to manage in COS, what we need to create in prefix plan etc.
Help for database - in system doc (on disk) you have zip file (...\cdrom\content folder), like dm09011b0280190c33.zip. Unzip this file and run index_en.html from unzipped folder.
nhou
MichaelGPN
Thank you for the information! Really helpful!nhou wrote: ↑23 Mar 2016 16:22 Hello,
Try this
http://alcatelunleashed.com/DBMGT/html/ ... egory.html
Is there other links like this one with explanation of each variable.
- frank
https://www.alcatelunleashed.com/viewforum.php?f=409
I actually added the Database management for R100
