SIP Connection between OXE
danntel
Post by danntel »
I would like to create a connection between two OXE systems; i don't want to create an ABCF network, cause i basically need to conect a lab OXE to a critical customer production OXE. So, i think SIP trunk will be easier and less problematic than creating ABC networks and merging DBs and so on...
Is there any TC that explains how to connect two OXEs using SIP Trunks?
I was thinking that each OXE should have:
- SIP Trunk
- SIP Ext GW
- Trunk Group Prefix
But i got lost on how the SIP Trunk can associate the SIP Ext GW...
BW: The SIP Trunk will mainly provide calls between OXE_LAB and OXE_PRODUCTION, right? There won't be any feature like manager/secretary, transfers, conferences and so on, right?
Hope you can help
Re: SIP Connection between OXE
system doc/ IP-PCX networks/ SIP/ SIP trunking - you can find explanation and examples.
at trung group n 1799 level>>>>> Remote Network : 14 fe
at sip extgateway n1 level>>>>>Trunk group number : 1799
Network Routing Table>>> network n0 14 >> Associated SIP gateway : 1
for transfert and conf you should have those features with different variant
networked managersecretary should note work cause no networked link (abcf)
Return to “SIP”
