4200c
timbo2272
4200c
Post by timbo2272 »
hi all. new to this forum and would just like to say hello to all u alcatel guys,
just wondered if any of you had any programming docs for a 4200c, have some basic programming steps from the phone user guide, i am familiar with setting up phone system via keypad (nortel, panasonic, toshiba systems, have been in comms 25 yrs). any help would be appreciated.
thanks in advance.
tim
Re: 4200c
That's a very old system (not even D :shock: ). I'll try to find something in my oldies docs.
luckyme2
Re: 4200c
Post by luckyme2 »
tot3nkopf wrote:That's a very old system (not even D :shock: ). I'll try to find something in my oldies docs.
:D :D Old ? :shock:
I remember the Telic 1600 Pbx which was the predecessor of the Alcatel 4200 c/d/e systems.
Say, during the 80's.
:) 8)
A+
et
Re: 4200c
Post by et »
4200c is the same like D, but in smaller number of subscribers and lines. You can found one 4200c in DECT coverage tool suitcase.
timbo2272
Re: 4200c
Post by timbo2272 »
hi.
thank you all for ur replies but i have another question, can u connect a laptop to this system via the 9 way d-types and if so what programme tool do i need.
thanks
et
Re: 4200c
Post by et »
The software tool called PCMMC. There are exist different versions, I think, the latest one - paa422_28_0. You need a direct cable with DB9 on both ends. For management 3 wire enough, connecting pins 2,3 and 5 on DB9.
macro_nit
Re: 4200c
Post by macro_nit »
Do you know where to obtain the tool?
Cartoon
Programming/Installation manuals and SW -docs for A4200 Seri
Post by Cartoon »
Programming/Installation manuals (HTML) docs and software for the A4200 Series you can find on this link:
http://www.a4400.spb.ru/a4200.html
or in ZIP file:
A4200 Installation Manual HTML.zip
Cartoon
Présentation générale Alcatel 4200 (PDF)
Post by Cartoon »
Présentation générale Alcatel 4200 (PDF) with notices and descriptions on French language.
Cartoon
Post by Cartoon »
Présentation générale Alcatel 4200 (ZIP-PDF) with notices and descriptions on French language.
Présentation générale Alcatel 4200.zip
